Go to Post Frank is frank, and I like that. - rsisk [more]
Unread 16-02-2015, 21:34
noah10001 noah10001 is offline
FRC #5447
noah10001 is an unknown quantity at this point
Need help with programming double solenoids
Hello, I am new to Labview programming and I was trying to program a double solenoid using an example code. Their code is from 2011 and I ran into trouble with wiring it to the "boxes" the attachments are my code and the sample code i used. I also cannot find how to get the joystick "box" etiher
ID:	18392  Click image for larger version
Unread 16-02-2015, 21:46
Re: Need help with programming double solenoids
Use this example updated for 2015 instead.
If you save the example picture, then drag and drop in on your block diagram it will generate the code.
Unread 16-02-2015, 21:47
jSchnitz's Avatar
jSchnitz jSchnitz is offline
Lead Programmer, Operator
AKA: Jacob Schnitzlein
FRC #1986 (Team Titanium)
jSchnitz is on a distinguished road
To get a joystick value now you'll need to use the Index Array function rather than Unbundling by Name, like so
Unread 17-02-2015, 07:53
FRC #5447
Thanks! but how do I set what button is forward and which is reverse
Unread 17-02-2015, 08:24
Use the "Sticky Solenoid Example" on the page Mark pointed to. The integers connected to the Index Array function select which button values come out of the function. It's a zero-based array, so "1" is actually the second button.
Unread 17-02-2015, 09:24
FRC #5447
Alright I am very close I have a xbox controller and I want it so Y is up and A is down. here is what i got. Even trying all buttons it doesn't work
Unread 17-02-2015, 10:28
The enums in Teleop are incorrect for Solenoid Set. That's why they have red dots.
Get a correct Solenoid Set Enum by
  • Deleting the wire into Solenoid Set (the one with the red dot)
  • Right-click on the now vacant Solenoid Set input node and choose Create->Constant
That's the correct Solenoid Set enum type.
  • Now make copies of the correct one and replace all the others
  • Finally, remove the enum you created into Solenoid Set and wire Solenoid Set into the Select as it was before.
  • If done correctly all the red dots should be gone.
Unread 17-02-2015, 16:49
FRC #5447
Alright this worked! Now when i push a button my air cylinder goes all the way up or all the way down. Is there any way to have an in-between..I attempted to code the right stick on the xbox controller but said there were two different data types
Unread 17-02-2015, 17:07
Simple answer: no. Pneumatic solenoid valves are two-state devices. There is no middle ground.
Complicated answer: with sufficient analysis and design, one can devise a way to use multiple solenoid valves and flow restrictors to cause a pneumatic cylinder to retract or extend an arbitrary amount. It will move in a spring-like fashion due to external forces, so some sort of feedback on its actual position would be helpful.
Unread 17-02-2015, 17:23
FRC #5447
When i click the buuton it is one-and-done.We want the button while pressed to flow and when released no flow anyway for this?
Unread 17-02-2015, 18:19
Do you mean like this example?
The solenoid here is Forward only as long as the button is held.
Unread 18-02-2015, 07:53
FRC #5447
So is there a way to lift a joystick to lift the cylinders some and then let go and it will hold that pressure until i move to joystick again?
Unread 18-02-2015, 08:04
You can't do it with a double solenoid valve connected to a typical pneumatic cylinder.
It is possible to do something like what you are asking by using multiple solenoid valves connected in creative ways, but it is not something you will find an off-the-shelf solution for. However, it will be very difficult to make it meet the pneumatics rules, which require that the working pressure never exceed 60 psi.
