Go to Post Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together. Nothing works and nobody knows why. - CalTran [more]
Unread 17-02-2015, 09:59
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: Problems with VI after integrating into robot project.
Well, we fixed the problem. We made a change to our motion filter sub-vi.
I think the issue is that although we set sensible default values that should have given a sane size for the array at compilation, there was no error checking to catch insane values or sizes that may be undefined or not a number. The array initializer wants an integer input for the size, rather than an unsigned int. For all I know, the value the compiler could have been accounting for may have been a very large negative number.
We coerced the array size to between 1 and 10 elements, which is generous for all of our anticipated use cases. We can always bump up the upper limit if we need a slower ramp rate.
If you are interested, the code is at our git repository, posted above.
