Noodle Agreement for Coopertition
Wow, noodles really mess up the field .... for the other guy. It can interfere with getting to the Step to stack the yellow totes.
I propose the following noodle agreement: No throwing noodles until after the yellow totes are stacked on the step. |
Re: Noodle Agreement for Coopertition
They would be lynching themselves. Coopertition is a lot of points to give up in what I think will be an otherwise low scoring game.
I was referring to the original noodle agreement thread where someone drew up a contract that they would basically force everyone to sign by manipulation and extortion.
I will propose this:
I don't think the Coopertition Bonus will be in play in very many matches. I'd go into reasoning, but that's a bit off-topic. Given what I've seen so far, and thinking maybe a bit harder than I should be... There are two questions that need to be asked between the alliances, the first of which will make the second one relevant or irrelevant. 1) Do you guys want to go for the Coopertition Bonus (stack or set)? 2) If so, would you be willing to hold off on throwing Litter until the bonus has been scored? (If the answer to the first is "no", obviously all bets are off.) |
Given what I saw on webcast, waiting to throw litter and not doing silly things to your landfill can really help in getting coopertition done (assuming litter is as easily thrown as at Suffield).
#7
From what I saw on the suffield stream, coopertition could make up a lot of points, and holding off on the noodles would be a good idea.
#8
Very disappointing Autonomous attempts. Wonder how many elimination matches will involve anonymous as a scoring factor. Best I saw in 5 minutes was TWO 4+Bin+noodle and a ONE 5 stack but that was 5 minutes not 2:15. I saw 3 in other matches cooperative stacks again in 5 minutes. Some that tried and could not reach step. Time is going to be a huge factor ...we purposely scrimmaged using 2:15. To get used to actual speed of the game learning to be efficient. Suffield to me looked in slow mo after just coming from our scrimmage. Noodles can definitely be a nuisance often I saw 7 on the field that's -28 points unless your alliance matches....also looks hard to accurately sweep noodle into open landfill areas. Sort of have to have some sort of an agreement ahead of time or noodles may mess up the best laid plans of your alliance IF you don't have a counter strategy. Almost have to approach this the way the US/USSR did with MAD. Last edited by Boltman : 17-02-2015 at 10:54. |
#9
The other alliance was able to get 7/10 noodles across the step and over your landfill? That's very impressive and I doubt that will happen often. Also it is not -28 points, it is +28 points for the other alliance. That's a huge difference since matches are not played head to head. That would be like saying a coopertition stack in a match you were not in is -40 points for your team...
#10
Noodles are going to be a nuisance for sure, especially for driving as they start raining down as soon as Teleop starts but at the Week 0 event in Merrimack, I noticed only one or two that was severely in the way.
However, coopertition is a huge point swing for both alliances so it would benefit them to try and get it as soon as possible. If agreeing to not start the hailstorm of noodle fire until after the set or stack is completed, I wouldn't argue. The fastest to the step gets the containers too... |
#11
Honestly, I don't see why you would start throwing noodles early. In this year's points setup, it doesn't help you to pull the other alliance down (game pieces from the step that you score excepted). Assuming that you can throw a noodle in 2 seconds, it is best to wait until about 45 seconds before the end of the match, and throw all of it then, leaving a minimum amount of time for the other alliance to process it. (Not that it's likely anyway, at 1 point.)
#13
To mess up the field for the other team. The litter gets in the way of clearing the landfill.
#14
You might get say 28 if very lucky with throws with say 7 noodles but loose 12 extra potential (40)..by throwing them too early and negating the other alliance from completing the cooperative stack. Last edited by Boltman : 17-02-2015 at 14:41. |
#15
