Go to Post Yeah, you build robots, so what. But you also build students, and that's what it's about! - DonRotolo [more]
Unread 17-02-2015, 15:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Robot Size
Originally Posted by npalachuk View Post
we have a robot that measures 31 x 34. Are we too big?
Originally Posted by rtfgnow View Post
There is no size limit on the field this year. Between the field and your pit you must be able to fit within 28" by 42" by 78". That means you need to be able to collapse your robot to be legal.
If it's under 28" tall (not likely, but just in case), you can transport your robot on its side so that it is 31" or 34" tall. Especially at the eleventh hour, think outside the box to figure out how to get inside it. If you think it can be done but you don't quite see how, post a pic or two and maybe someone will suggest something.
