Go to Post Its not the type of material you use, but how you use it... - jrocket567 [more]
Unread 17-02-2015, 16:06
Re: Question about encoders and degree measurements?
Originally Posted by NHoffmann View Post
the encoders are mounted on the motor ... 497 encoder pulses is 1 motor revolution.
If you are using the same definition of "pulses" that US Digital uses, for a quadrature encoder you cannot have an odd number of encoder pulses per motor rev if the encoder is mounted directly on the motor shaft.
Are you sure the encoder is mounted directly on the motor?
AndyMark sells a 7 "PPR" encoder, but that spec probably means 7 CPR (cycles per rev).
Interestingly, 497 = 71*7. Coincidence?
