Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
Unread 02-01-2015, 23:44
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Talking Team 900 - nVIDIA Jetson TK1 OpenCV Co-Processor
Hi Everybody!
The student programmers here at Team 900 have done a wonderful job of getting a nVIDIA Jetson TK1 to process images from an HD(Logitech C920) USB camera, detect our Frisbee targets, and send the information to the roboRIO to act on. The code is a tad bit messy in a "few" places, and we could probably speed up the processing, but hey, it works.
We have the Jetson TK1 powered through the VRM(Voltage Regulator Module) on the 12v@2A bus.
nVIDIA Jetson TK1 Code: https://github.com/FRC900/OpenCV-Tes...risbeelocating
roboRIO BETA Code: https://github.com/FRC900/2015Beta
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
Unread 17-02-2015, 17:06
memyselfandi memyselfandi is offline
FRC #3826
memyselfandi is an unknown quantity at this point
Re: Team 900 - nVIDIA Jetson TK1 OpenCV Co-Processor
Team 3826 is trying to use the Jetson. We pulled the source code from the link "nVIDIA Jetson TK1 Code:". We've tried to compile it and are getting the following errors:
$ make
-- Configuring done
-- Generating done
-- Build files have been written to: /home/mgb/900_opencv/frisbeelocating
Scanning dependencies of target testing
[ 50%] Building CXX object CMakeFiles/testing.dir/gpuTesting.cpp.o
c++: warning: ‘-mcpu=’ is deprecated; use ‘-mtune=’ or ‘-march=’ instead
c++: error: unrecognized command line option ‘-mfpu=neon-vfpv4’
c++: error: unrecognized command line option ‘-mvectorize-with-neon-quad’
make[2]: *** [CMakeFiles/testing.dir/gpuTesting.cpp.o] Error 1
make[1]: *** [CMakeFiles/testing.dir/all] Error 2
make: *** [all] Error 2
[1]- Done emacs Makefile.cmake (wd: ~/900_opencv/frisbeelocating/CMakeFiles)
(wd now: ~/900_opencv/frisbeelocating)
[2]+ Done emacs CMakeCache.txt
I've found the -mcpu can be changed to -mtune using the same parameter to remove the -mcpu error, however, we don't see a work around for the other two errors.
We're compiling on ubuntu on a VirtualBox VM running on Win7 with the Jetson TK1 installed. Have this been seen before? Any suggestions?
Thank you.
Unread 18-02-2015, 07:41
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
FRC #0900
Rookie Year: 2015
KJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud of
$ make
-- Configuring done
-- Generating done
Thank you.
Looks like you're compiling for x86 rather than ARM. Remove those two ARM-specific options and the code should build correctly. Or alternatively, you could push the code to a Jetson board and build there and things should just work.
If you're trying to cross-compile (build ARM binaries on an x86 Linux host machine) you'll need to point to the correct compiler. The compiler name is usually of the form "arm-none-linux-gnueabihf-g++" or the like. Sometimes "none" is called "unknown" instead, but the general idea is the same.
If you are planning to run on x86, be aware that the code is written to run on the GPU. If I remember there are fallbacks to run on the CPU, but the CPU code wasn't the focus of our development effort so it may be different than the GPU code.
Unread 20-02-2015, 15:52
FRC #3826
Thank you for your response and help.
We are compiling for the Jetson, but building on a Ubuntu system. We did take you suggestion and point to the correct compiler, we are not compiling. We are now working through some what I think are link problems and pointing to x86-65 linux libraries instead of ARM libraries.
Thank you again for your help.
Unread 20-02-2015, 19:48
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
We used a Jetson this year, and compiling OpenCV on the Jetson took about 40 minutes utilizing all 4 CUDA cores. I wouldn't worry too much if you have to do it on the board.
ORB Haow!
Unread 20-02-2015, 20:28
yash101 yash101 is offline
AKA: null
40 minutes is insane. Our ODROID X2 is able to compile the latest OpenCV with a gazillion features in about 10-20 minutes. How many jobs are you using? I'd suggest you use at least -j 6 or maybe -j 8 when compiling on the jetson. It's got plenty of power for that!
Unread 24-02-2015, 01:08
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
How is that working out? The sticker on our Jetson suggests that we need a 4.8A power supply (which seems extremely high for a mobile chip). Have you had any slow-downs or drop-outs from consuming too much power?
Unread 24-02-2015, 14:23
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
I can't find the thread, but I believe I've seen someone from NVIDIA mention that 4.8A was way overkill, and they would be refining the requirements later. On my bench setup, I haven't seen the Jetson draw more than 1.5 amps at 12V, and this was during testing of low voltage conditions on the regulator.
The kind folks at elinux.org have benchmarked power consumption for various tasks, looks like nothing draws more than 12 watts of power: http://elinux.org/Jetson/Computer_Vi...r_vision_tasks
If you have additional peripherals, that may raise your power budget, but I'm comfortable running it off of the 12V regulated supply.
Unread 02-04-2015, 08:42
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Thought I would take a moment to update this thread with some sample video from Palmetto this year:
https://www.youtube.com/watch?v=w1ZSzxw84So
We're tracking the recycle bins. I can't talk a lot about the technical nitty gritty but I can tell you that it is using OpenCV and it is running on the GPU of the Jetson. There are another couple of folks who can shed more light on the technical details if you are interested.
Unread 02-04-2015, 14:04
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
How many of the cuda cores are you using? What's the average fps?
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 02-04-2015, 15:14
marshall's Avatar
All of them as far as I know. The FPS is in the video but somewhere between 5 and 10 from what I know about it. Hoping to double that with some upgrades after the season is through and we can put more effort into this.
Unread 02-04-2015, 15:37
faust1706's Avatar
I'd be more than happy to help you optimize the code, as 1706 is going to be getting a jetson board to experiment with.
You must be running some very inefficient code if you're only getting 5-10 fps with gpu accelerated opencv (http://opencv.org/platforms/cuda.html)....We are using a depth camera and are getting 26 fps on the odroid XU, which has the same amount of ram and an older arm based cpu and cannot be gpu accelerated.
Anyways, the video you posted is really cool and seems to work very well. Good job on whoever wrote that. I'm sure many teams would eat up a whitepaper about it.
Unread 03-04-2015, 10:27
marshall's Avatar
Awesome sauce! One of the students has volunteered to work on a white paper but I'm not sure how far along he is on that. I believe he is working on it though. I'll be pestering him about it over the next few months.
I can't speak to the efficiency of the code but it was written largely by students and it is doing what we were aiming for. I suspect there are a lot of improvements we can make but I know the resolution has a lot to do with the lower frame rates. We'll keep perfecting it though and it will get published publicly at some point... likely alongside the white paper.
Unread 08-04-2015, 16:21
Team Captain
AKA: Sam Weaver
Team 4534 used the same system this year, it might be worth building a library for the Rio. Let us know if you have any questions or want to compare how our systems worked.
ORB Haow!
Unread 28-04-2015, 15:13
Caboose's Avatar
AKA: James Parks
Smile Re: Team 900 - nVIDIA Jetson TK1 OpenCV Co-Processor
Hey all,
I just posted links to 900's code, including vision, over here. Ask questions if you have any there please.
myManga
