Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 16-02-2015, 13:38
Coconut tree Coconut tree is offline
FRC #0240
Coconut tree is an unknown quantity at this point
2 cameras on the dashboard
Hello, I'm trying to get two cameras to appear on the dashboard. I already have one working but I am having trouble with the second one. I'm using the Microsoft life cam 3000, and the FRC dashboard project in labview.
Unread 16-02-2015, 14:47
ColMacprogrammi ColMacprogrammi is offline
FRC #0240
ColMacprogrammi is an unknown quantity at this point
Re: 2 cameras on the dashboard
We need a solution for this problem.
Unread 16-02-2015, 15:22
RobotMonkey RobotMonkey is offline
FRC #1413
RobotMonkey is an unknown quantity at this point
I don't think what you are asking is that easy. We are using two cameras, but are switching between them. I am using the code adciv posted in this thread.
http://www.chiefdelphi.com/forums/sh...d.php?t=133771
I can confirm it works fine for switching between two usb cameras. I mapped the toggle to a joystick button, rather than using a dashboard switch.
Unread 16-02-2015, 19:33
FRC #0240
thanks for the help I downloaded the file, but I don't know what to do with it.
Please Help!
Unread 17-02-2015, 11:17
It is actually not that hard to customize the DB, adding an image display to the custom tab and connecting it to a camera. I have done this and found that having multiple Axis cameras or one USB and one Axis is pretty easy. The WPILib code doesn't support multiple streaming USB cameras at the same time.
Greg McKaskle
Unread 17-02-2015, 17:16
FRC #0240
Greg McKaskle
Ok i swapped one of the usb cameras with an Axis camera, but i'm still not getting an image.
