Go to Post Learn the subjects that interest you, but at the same time know how it relate to real life situations, and how it is applied. - Ryan Dognaux [more]
Unread 13-02-2015, 15:38
seabasssl seabasssl is offline
FRC #3711
seabasssl is an unknown quantity at this point
USB Camera on the SmartDashboard
Hey everyone! We've been having some issues with the USB camera not showing up on the SmartDashboard. Many of the threads I've read on here haven't given us any significant results, about our issue.
We are getting the "Huffman table not defined" error - we're running on a 64 bit OS. I had two cameras working the first time I tried it, and then the next day, we couldn't even get one to work.
There is a reading on the DriverStation, when the USB Camera HW option is selected, but no image display.
Unread 14-02-2015, 05:26
RyanCahoon's Avatar
RyanCahoon RyanCahoon is online now
FRC #0766 (M-A Bears)
Re: USB Camera on the SmartDashboard
Have you tried my solution? http://www.chiefdelphi.com/forums/sh...d.php?t=134404
FRC 766, 2015-, Mentor
Unread 14-02-2015, 14:21
FRC #3711
Thank you for your patch, seems like it's an awesome solution - but I'm not getting any visual from the camera still.
Unread 15-02-2015, 04:28
RyanCahoon's Avatar
What code are you running on the robot to transmit the camera images to the driver station?
Just to clarify - are you using SmartDashboard or the LabVIEW/default dashboard?
Do you get the same error or a different one when you use my version of the applet? If you are getting an error with my applet, there should be files placed at C:\Users\<user name>\SmartDashboard\extensions\ named error.txt and frame.jpg. Can you upload them?
Thanks,
Unread 15-02-2015, 14:31
FRC #3711
I am using the Simple Vision example code
CameraServer::GetInstance()->SetQuality(50);
	CameraServer::GetInstance()->StartAutomaticCapture("cam0");
	CameraServer::GetInstance()->StartAutomaticCapture("cam1");
I added the "cam1", however, because we've been having issues with the RoboRIO not registering "cam0", but instead will just recognize the camera as cam1 and up.
On our prototype robot, we're having success with one camera - but not on our "final" robot, even when using the same RoboRIO, and code from our prototype robot.
We had success with both the SmartDashboard and the standard Driver Station on our prototype robot.
Here's the error log error.txt
The frame.jpg has no data in it.
Unread 16-02-2015, 04:48
RyanCahoon's Avatar
Try removing the first call to StartAutomaticCapture. From the source code for CameraServer, it looks like only the first call to StartAutomaticCapture will have any effect, so your code will be trying to stream from cam0.
See here for instructions on determining the names for your camera(s): http://wpilib.screenstepslive.com/s/...amera-C++\Java
Unread 17-02-2015, 10:27
joliet cyborgs joliet cyborgs is offline
FRC #4241
joliet cyborgs is an unknown quantity at this point
Copying and pasting the code from the Image Processing example code worked for us. You just have to make sure to put each section of code in the right place.
Unread 17-02-2015, 12:52
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
Just having one call to StartAutomaticCapture with the correct name (ie cam2) got things going. We will give up on getting 2 cameras going.
Now the image is seems overexposed. If I use change speed slider bar on dashboard, the image is good for one or 2 update, then back to overexposed. Any ideas?
Unread 17-02-2015, 17:17
RyanCahoon's Avatar
You could modify the Intermediate Vision example to allow you to switch between cameras.
#include "WPILib.h"
 * Uses IMAQdx to manually acquire a new image each frame, and annotate the image by drawing
 * a circle on it, and show it on the FRC Dashboard.
class IntermediateVisionRobot : public SampleRobot
    IMAQdxSession camera1;
    IMAQdxSession camera2;
    Image *frame;
    IMAQdxError imaqError;
public:
    void RobotInit() override {
        SmartDashboard::PutBoolean("Camera Select", true);
        // create an image
        frame = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
        //the camera name (ex "cam0") can be found through the roborio web interface
        imaqError = IMAQdxOpenCamera("cam0", IMAQdxCameraControlModeController, &camera1);
        if(imaqError != IMAQdxErrorSuccess) {
            DriverStation::ReportError("IMAQdxOpenCamera error: " + std::to_string((long)imaqError) + "\n");
        imaqError = IMAQdxConfigureGrab(camera1);
            DriverStation::ReportError("IMAQdxConfigureGrab error: " + std::to_string((long)imaqError) + "\n");
        //the camera name (ex "cam1") can be found through the roborio web interface
        imaqError = IMAQdxOpenCamera("cam1", IMAQdxCameraControlModeController, &camera2);
        imaqError = IMAQdxConfigureGrab(camera2);
    void OperatorControl() override {
        // acquire images
        IMAQdxStartAcquisition(camera1);
        IMAQdxStartAcquisition(camera2);
        // grab an image, draw the circle, and provide it for the camera server which will
        // in turn send it to the dashboard.
        while(IsOperatorControl() && IsEnabled()) {
            bool which = SmartDashboard::GetBoolean("Camera Select");
            IMAQdxSession& capture_cam = which ? camera1 : camera2;
            IMAQdxGrab(capture_cam, frame, true, NULL);
                DriverStation::ReportError("IMAQdxGrab error: " + std::to_string((long)imaqError) + "\n");
            } else {
                CameraServer::GetInstance()->SetImage(frame);
            Wait(0.005);                // wait for a motor update time
        // stop image acquisition
        IMAQdxStopAcquisition(camera1);
        IMAQdxStopAcquisition(camera2);
START_ROBOT_CLASS(IntermediateVisionRobot);
If you want to stream cameras simultaneously, the easiest way would probably be to do some small modifications to the CameraServer class and the dashboard widget to configure different ports for the streams. Be careful about saturating the field bandwidth if you do that, though.
I'm not sure what the 'speed' slider adjusts, but try changing the exposure on the camera. You may be able to do it through the RoboRIO's web interface (don't have one in front of me to check), but here's how you could do it in code:
std::shared_ptr<USBCamera> camera(new USBCamera("cam1", true));
camera->SetExposureManual(50); // change this value
camera->SetBrightness(50); // change this value
CameraServer::GetInstance()->StartAutomaticCapture(camera);
Unread 18-02-2015, 10:00
AKA: rod nelson
Thanx Ryan, we will try those things on spare robot. The students have a bad case of Bag and Tag Burnout, so we will hit it on Saturday.
