Go to Post The GDC giveth, the GDC taketh away. Blessed be the name of the GDC. - GaryVoshol [more]
Unread 17-02-2015, 17:32
Re: Axis/Slider Scale
Originally Posted by Ozuru View Post
The range is from -1 to 1 and I need to convert it to be from 0 to 1 rather than -1 to 1.
Originally Posted by Jared View Post
(stick.get() + 1) / 2
Jared gave you the answer.
If you are interested, here's the algebra to solve that kind of problem, for any input and output range, assuming you want a linear conversion from input to output:
Let x be the input and y be the output.
You want a linear conversion, so use the equation for a line:
y = mx + b
When x is -1 you want y to be 0:
0 = m(-1) + b ....(Equation1)
When x is 1 you want y to be 1:
1 = m(1) + b .....(Equation2)
You have 2 equations with two unknowns, so solve them.
Add the two equations:
1 = 2b .....=>..... b = (1/2)
Subtract Equation1 from Equation2:
1 = 2m .....=>..... m=(1/2)
So the conversion is y = (1/2)x + (1/2) = (x+1)/2
