Go to Post FIRST is the best thing I could have ever done. It shows me where I think my limits are, and it destroys them right in front of my eyes. My experiences with FIRST have defined who I am, and I am beyond blessed to have had them. - Audrey Chu [more]
Unread 16-02-2015, 20:21
robinspi's Avatar
robinspi robinspi is offline
Design Captain
AKA: Philip
FRC #5450 (SHREC)
Team Role: CAD
Rookie Year: 2015
robinspi is an unknown quantity at this point
Rules issues...
I don't exactly know where to post this, but here goes...
Can we use compressed air to "prime" the pneumatics system before a match starts? To be precise, from an external source?
Unread 16-02-2015, 20:23
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Rules issues...
No, see rules R68, and R69.
Originally Posted by Manual Section 4.10 Pneumatic System
R68 Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
R69 The compressor (permitted per R68) may be located off-board, however the compressor must still be controlled and powered by the ROBOT.
You can, however, fill the tanks with the robot compressor before a match.
Originally Posted by R69 Blue Box
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 16-02-2015, 20:24
Re: Rules issues...
Yes... but no.
Yes, you can charge your pneumatics system before entering the field for a match.
No, you cannot use anything other than the robot's one and only one compressor, onboard or offboard, run by the RoboRio. (R68)
Unread 17-02-2015, 09:14
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: Rules issues...
And be prepared to demonstrate it for the inspectors. They will need to verify:
  1. You are using the FRC approved compressor
  2. That it is powered by the FRC approved battery
  3. That the compressor is controlled by the roboRio
  4. That all pneumatic requirements are applied to the compressor setup as well as the pneumatic system on the bot (we put regulators, pressure release valves, and indicators on both setups i.e. everything required to be on the robot was also put on the compressor setup)
We have successfully done this several times and with the old compressors it saved us on weight. With the new compressors being so lightweight you must be in a real estate or weight crunch to need to keep it off-board.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 17-02-2015, 10:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Rules issues...
R68 and R70 would prevent it.
R68 says one and only one compressor, and when that compressor generates pressure, R70 says it can only be stored on the robot.
So, for a robot with an on-board compressor, there is no way for an external source to provide air (either generate, or temporarily store for future use).
Unread 17-02-2015, 11:06
AWoL's Avatar
AWoL AWoL is offline
Lvl. 225 Dark Code Mage (Java Type)
AKA: Adam Wolnikowski
FRC #0225 (TechFire)
AWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond repute
Re: Rules issues...
Or a power crunch
2016 Competition Results (Co-captain, Driver, and Lead Programmer; Junior)
Springside-Chestnut Hill District Event - WINNER / #2 Seed, #1 Seed's First Pick / Gracious Professionalism Award
Westtown District Event - WINNER / #1 Seed / Industrial Design Award
MAR District Championship - WINNER / #1 Seed / Industrial Design Award / Dean's List Finalist Award (Me)
World Championship, Carson Subdivision - QUARTERFINALIST / #3 Seed, #2 Seed's First Pick
Indiana Robotics Invitational - FINALIST / #14 Seed, #2 Seed's Second Pick
Unread 17-02-2015, 20:07
robinspi's Avatar
Design Captain
AKA: Philip
FRC #5450 (SHREC)
Team Role: CAD
Rookie Year: 2015
Lightbulb Re: Rules issues...
Okay, so we would be able to have the compressed air tank be full before the match... Thank you all. Actually, it was either my team being bad at communicating, or me misunderstanding the question, but anyway... I got my answer.
