Go to Post I don't thinks shorts should be allowed in the pits. Remember to insulate all of your wires! - Jalerre [more]
Unread 17-02-2015, 20:47
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: We need help... A lot of it
Originally Posted by GeeTwo View Post
A second cable is only needed if your lift plate is too light, or your friction is too heavy, for the lift to lower itself. As I read your posts, your first cable (pull on lift) is also your second cable (pull on lower). If this is correct, you can pretty much ignore the "second cable" posts.
Also, if this is correct (that is, your cable is doubly terminated on the chassis end), you can make your system more repeatable/reliable by adding more wraps to the shaft/axle/spool on the lift side. This basically means making a somewhat longer cable in the shop (add one or two wraps around that spool), including it in your WITHHOLDING ALLOWANCE, then replacing it on the Thursday of your competition.
Yep. Often for winches, that's a bit larger and drum-shaped.
It's more of a "hold-in-place" on the wheel, giving it more cable to work with (having the same effect as a grippier wheel, theoretically). You'd have a tensioner (turnbuckles work well) elsewhere in the system and run a pretty tight cable for this trick to work, but it should be. Given that you've got a small(ish) wheel width-wise, you might be able to get away with 2 wraps.
I'm going to suggest following the procedure I posted earlier, with the cable not permanently terminated until you get the lift working reliably. It might take extra cable wraps or some grippy material or both, but it should give you some working room.
Thanks guys its such an easy fix Im mad we didnt get to do it today. The good thing is our mecanum wheels are working and I had a little bit of driving practice getting a good feel for this years control layout. We should be able to make all the fixes necessary in an hour or 2 on practice day of the comp. Thanks all
Unread 17-02-2015, 21:14
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Enjoy your competitions.
My favorite thread of the season.
Unread 17-02-2015, 23:13
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Always glad to help. I hope we ally with you on Einstein ;->.
Unread 17-02-2015, 23:21
Sperkowsky's Avatar
Miracles are real... I think
Unread 17-02-2015, 23:31
dtengineering's Avatar
AKA: Jason Brett
You might find the capstan equation interesting: http://en.wikipedia.org/wiki/Capstan_equation
Basically having a few wraps around the moving part of your winch increases the maximum pulling force exponentially.
You might see a few photos of 5742's robot with a 6" diameter steel pulley on the front of it. There are three wraps of 1/8" plastic coated wire rope around there, and it does not slip. http://www.chiefdelphi.com/media/photos/41356?
With two wraps it slipped a bit.
With one wrap is just spun uselessly.
You'll note that there is an eyebolt at the top of the 5742 lift to adjust tension in the cable. That also helps improve traction.
As far as linear slides are concerned, IGUS (the cool plastic bearing people) have some information on designing them at http://www.igus.ca/wpck/6109/TechTalk_Overview Check out the "2:1 rule" and "How to Eliminate Binding"
Good luck,
Jason
Unread 18-02-2015, 00:20
Sperkowsky's Avatar
Good luck,
Jason
Thanks man
Unread 18-02-2015, 00:57
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Absolutely. Miracles happen all the time. Too many of them go unappreciated.
Unread 18-02-2015, 01:25
Sperkowsky's Avatar
If that happens I will appreciate it haha.
