Go to Post Funding and success is no accident. - waialua359 [more]
Unread 02-17-2015, 07:07 AM
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Thomas Compressor
If we use Thomas Compressor using the PCM it is stop and wirking many time befor the Tanks is full.
I am trying to wire Thomas Compressor with SPIKE. with Power Distribution Panel 20 A .
is it O.K.
TEAM 1946-Tamra
Unread 02-17-2015, 07:13 AM
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Thomas Compressor
It's ok. Check R37 and R42
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 02-17-2015, 07:44 AM
Mohamed,
You can replace the 20 amp fuse in the Spike with a 20 amp circuit breaker for the compressor only. I highly recommend you make the change.
Unread 02-17-2015, 08:49 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I support Al's recommendation to replace 20A fuses with 20A snap action breakers in Spike relays that feed compressors, especially the Thomas 405ADC38/12.
Look here for some test data that may help understanding why this recommendation is important.
Richard Wallace
since 2003
Unread 02-17-2015, 09:06 AM
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Which Thomas Compressor?
R68 Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal
12VDC, 1.05 cfm flow rate.
Unread 02-18-2015, 01:10 AM
yara92's Avatar
AKA: Mohamed
Wiring the Compressor/ to
The Power Distribution Panel
What about Pressure Switch can we use Pneumatics Control Module.
TEAM 1946-Tamra
Unread 02-18-2015, 01:15 AM
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
If you wire the compressor to the PDP, you want to wire your switch to the DIO on the robo-rio so you can control it in your code. If you were to wire it to the PCM, it would be difficult to access the pressure switch value.
If you wire the compressor to the PCM, then you should wire the pressure switch there as well.
Unread 02-18-2015, 02:26 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We aren't using any pneumatics this year, but I have been in on several support threads. While using the spike to control the compressor is legal, it is really not the best solution. The PCB has circuitry to dampen the transient as the motor starts up, reducing the likelihood of tripping the fuse/breaker in the first place. I'm a "late adopter" who only uses something new when it is either mandatory or a clear improvement over the old-and-trusted. From what I've read, I'd rather use the PCB to control the compressor this year. If you decide to go the Spike route, a breaker rather than a fuse is a must!
Unread 02-18-2015, 06:04 AM
yara92's Avatar
AKA: Mohamed
I understand what you say, I have problem that we use the Thomas Compressor, 1/10 HP Model: 405ADC38/12 it is not working until it up 120 PSI about 70 psi stooping then after a while continue working.
So I don’t know where is the problem . I use the wiring PCM
TEAM 1946-Tamra
Unread 02-18-2015, 09:15 AM
That compressor is rated for 100 psi. It will likely not stop running until the thermal switch on the compressor stops it. And then, it will not restart until the thermal switch resets.
The Nason pressure switch trips around 115 psi, well above the rated pressure of the compressor. It should not pressurize the system to the "fully charged" 115 psi level.
I don't know whether it is allowed to adjust the Nason switch to trip at a lower psi.
Unread 02-18-2015, 11:06 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If this is the old FRC compressor, it will run to 120 PSI, no problem. The pressure switch is sealed. It is somewhat adjustable, but it would no longer be First legal. Since the rules require a specific part number, you cannot order it with a lower set pressure. Lot of discussion about this last year.
Unread 02-19-2015, 02:21 AM
yara92's Avatar
AKA: Mohamed
It It doesn't work by
Compressor Recharge Current Test Bench Set Up
test set up 48.pdf
TEAM 1946-Tamra
Unread 02-19-2015, 11:34 AM
Mohamed,
There could be one or two things that are having an issue here. There is a thermal breaker inside the compressor that takes several minutes to reset once it trips. If you block the air slots on the side and end of the compressor, it will over heat. We are also unsure if the PCM can handle high current for this compressor. I would suggest you connect the compressor directly to the PDP through a 20 amp breaker please. See if it runs for a longer period than when controlled. It should reach well above 120 psi. That compressor is rated for 100psi but can easily pump up to 150 psi if it runs continuous.
The Nason pressure switch is not adjustable. The adjustment that people talk about simply sets the trigger for the internal microswitch. If mis-adjusted it will either not start or not shutoff. The factory makes the correct adjustment during production and then seals the adjustment screw.
It is also possible that you have an electrical issue between the PDP, the PCM (if you are using one) and the compressor. If one of the connections is loose, it will eventually heat up and fail intermittently.
Unread 02-19-2015, 11:41 AM
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Mohamed,
I've tripped the internal compressor breaker by blocking the compressor's output air port, with a PCM. This is part of testing.
Do not connect the compressor directly to the PDP. Please read the PDP's User's Guide, which states not to do this.
Unread 02-19-2015, 11:45 AM
Oz,
I made the suggestion to try and diagnose the issue. If the PDP cannot handle the current then it cannot handle a CIM either. Connecting to the PDP through a 20 amp breaker for testing at least gives some electrical protection. We need to know where to look to suggest a fix.
Blocking the output port cannot not provide the necessary testing as it simply forces the piston to bypass compressed air. I would suspect that run current would only rise slightly in this condition. I am guessing that what is at issue here is a low voltage condition that is overheating the compressor armature.
