Go to Post As a real pig farmer*, I definitely endorse team 1902. - Andy Baker [more]
Unread 18-02-2015, 12:32
nfusselman1 nfusselman1 is offline
FRC #4076
nfusselman1 is an unknown quantity at this point
Re: Encoder
Talons
Unread 18-02-2015, 12:33
FRC #4076
Re: Encoder
and the regular kit weals (tile)
Unread 18-02-2015, 12:34
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Re: Encoder
My team uses jaguars, but the code might be similar. What language do you program in?
Unread 18-02-2015, 12:35
FRC #4076
Re: Encoder
java
Unread 18-02-2015, 12:45
Autonomous Queen
Re: Encoder
What our electrical team did was they wired optical encoders onto the axel and into the jag. Inside of the DriveTrain subsystem, I called a method on each of the jags to inform them that they have encoders. That portion of code looked like this:
rightFront.setPercentMode(CANJaguar.kQuadEncoder, encoderCounts);
Below that, I enabled encoder control on each of the jags:
rightFront.enableControl();
I was then able to use the encoders in other programs.
I wouldn't know without looking at the javadocs, but if I were to make an educated guess I would say that setting up encoders would be similar to this but with talons instead of jaguars.
Unread 18-02-2015, 12:47
FRC #4076
Re: Encoder
ok what kind of encoders did you get and how did you attach them.
Unread 18-02-2015, 12:51
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Encoder
What do you plan to use the encoders for? Making sure both wheels turn at the same speed or are you using it for finding out how far you have driven?
Unread 18-02-2015, 12:56
Autonomous Queen
Re: Encoder
We used optical encoders, I'd have to ask the electrical folks for more details. I'm working on incorporating them into autonomous mode.
FRC #4076
Re: Encoder
both but mainly distance.
Unread 18-02-2015, 13:53
Re: Encoder
These are the encoders our team purchased http://www.andymark.com/product-p/am-0180.htm and they are working extremely well for us. One thing we want to try is wiring them directly up to our talons (You can only do this if you have the talon SRX's).
If you cant wire them up to the talons then wire them up to the roboRIO, our team accomplished this by cutting up 2 unneeded PWM cables. We wired the cables like so:
(This image is not mine, I just found it online)
Then we programmed them link this
	Encoder encoderleft; //Declare the encoders so they are accessible in all methods
	Encoder encoderright;
	public void robotInit() {
		encoderleft = new Encoder(0, 1); //Initalize the encoder, A channel is plugged into DIO 0, B channel DIO 1.
		encoderright = new Encoder(2, 3);
		encoderleft.setDistancePerPulse(0.11); //did some math to calculate that for 1 pulse the robot moved 0.11 of an inch (Will be different for other robots)
		encoderright.setDistancePerPulse(0.11);
	public void autonomousPeriodic() {
		double distance = (encoderleft.getDistance() + encoderright.getDistance()) /2; //Find the distance robot has travled based off of the average of the 2 encoders.
		//Code to make your robot move off of the encoder values here
Unread 18-02-2015, 16:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Encoder
The encoders should be connected to DIOs, not PWM ports!
Unread 18-02-2015, 16:24
Re: Encoder
Yes, I agree, that diagram can be misleading out of context. The "PWM" in the diagram refers to the use of PWM cable/connectors.
In context (i.e. on the web page where the diagram came from) it explicitly says to connect the cable to DIO ports.
Unread 18-02-2015, 17:41
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Encoder
is there any reason why i wouldnt get an accurate reading from the encoders?
Unread 18-02-2015, 17:51
Re: Encoder
To avoid having two separate conversations about two unrelated questions in the same thread, it would be best if you started a new thread if your question is not related to the OP's question; and provide more detail about the problem you are experiencing.
Unread 19-02-2015, 15:28
NathanCJohnson's Avatar
NathanCJohnson NathanCJohnson is offline
FRC #5517 (District 5517 The Engineers on Fire)
Team Role: Driver
Rookie Year: 2015
NathanCJohnson is an unknown quantity at this point
Re: Encoder
Does that encoder work with the 2015 KOP chassis gearboxes? The video tutorial on the item page shows a different gearbox, so I just want to make sure it works with the KOP one.
We should have added encoders a while ago before bag & tag, but since we didn't we will be adding them during the 6-hour robot access period the week of our first district event. Currently our autonomous modes are based on a timer which isn't very accurate or predictable.
