Go to Post We tried to get clear aluminum, but it was on back order. They said it would be in by March 3, 2150. - S.Nickens [more]
Unread 18-02-2015, 12:36
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
pic: 4738: defaultName
Unread 18-02-2015, 13:23
Lord of Lazy
Re: pic: 4738: defaultName
It's a generic forklift/elevator design. #35 chain driven carriage, using one static arm and one non-static arm.
The gearbox is a dual CIM powered worm gearbox, but the weight of the carriage backdrives it when it's disabled, which is why we cannibalized the 2014 robot for a constant force spring to hold it up.
The omniwheels are the "life-alert" wheels. The wheels sit a little less than an inch above the ground when the carriage is all the way down. If the robot tips over with the carriage all the way up, all we need to do is to drive the carriage down to prop it back up. Untested, but hopefully works.
They also serve as a lining up mech for tote loading from a human player, although practice will be needed to make sure that the robot does not contact the chute assembly itself so we don't get a disable.
The drive system is a 3 wheel drive, 2 powered pneumatic wheels at the front and one unpowered omniwheel in the rear.
It's able to pick up totes the long way and the short way, the RC long/short way, and stack 3 totes on 3 totes. Not sure if the CoG is gonna be screwed up because we don't have enough totes to do so but the calculations allow it to do so without tipping over (knock on wood).
College sux yo
Unread 18-02-2015, 14:31
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Nice looking Robot! Good luck in San Diego! Love the Numbers..cool display!
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 18-02-2015, 15:23
Lord of Lazy
Thanks!
College sux yo
