Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 18-02-2015, 12:15
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
LOOKING FOR FESTOS
Does anybody have 4 double solenoid Festos or 8 single solenoid festos that they could sell me. Just name a price and I will pay instantly through paypal.
THANKS!
Unread 18-02-2015, 15:10
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: LOOKING FOR FESTOS
sorry we are low on them. try seeking out other MN teams. find a mn event and there are some links to team websites. not every team uses CD.. http://www.usfirst.org/roboticsprogr...egional-events
http://www.thebluealliance.com/teams
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 18-02-2015, 19:03
JCharlton's Avatar
JCharlton JCharlton is online now
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Try ebay? Bought some SMC there cheap.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 19-02-2015, 09:45
LFRobotics's Avatar
FRC #4623
Yeah I went on Ebay and bought a few of these:
http://www.ebay.com/itm/370723685828...%3AMEBIDX%3AIT
I believe they will work - they look similar to the Festos
Unread 19-02-2015, 11:12
bachster's Avatar
bachster bachster is offline
AKA: Katie Bach
FRC #2052 (KnightKrawler)
bachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant future
Please keep in mind R66:
The only pneumatic system items permitted on 2015 FRC ROBOTS include the items listed below.
C. Solenoid valves with a maximum 1/8 in. NPT port diameter
It appears that the ebay link is a 1/4" port size which would not meet this rule.
If using non-KOP solenoids (or any non-KOP pneumatics components), please also be prepared to demonstrate with a manufacturer's spec sheet that they meet R64: "All pneumatic items must be COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi (with
the exception of R66-D)."
Automation Direct is a good source for pneumatics components, and they provide a $30 voucher to FRC teams (see the flyer in your KOP). You could also try directly ordering from Festo. Be sure to order the correct fittings to attach to your 1/4" tube if you don't have them already. 1/8" NPT is the thread size commonly found on the fittings supplied by FirstChoice/KOP. (NPT refers to the thread sizing standard. The actual OD of the fitting is more like 0.4", so it can be confusing). I think Festos are typically metric fittings. The ebay link looked like a BSPT (British) thread standard which is similar in size to NPT but not the same pitch.
Unread 19-02-2015, 12:28
LFRobotics's Avatar
FRC #4623
They arent being used on the robot - they are being put on a test board
