Go to Post Show me the mentor who has never built a bad robot and I'll show you either a new mentor, a liar, or Andy Baker. - Andrew Schreiber [more]
Unread 18-02-2015, 21:57
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: Ground Clearance Vex clamping gearbox
We only damaged the field in the very first practice match, after that we never hit the platform again and we played probably 17 matches.
But we were told that since our ground clearance was so low that we "could" damage the scoring zones so our frame would not pass inspection. I felt this was odd because you are flagging a robot for what "could" happen in the field, but if the intent was to damage the field I am sure teams could find a way and we would have many more robots not pass inspection.
For teams with low clearance just avoid the zones but probably start brainstorming options to raise your frame just in case.
Good enough is the enemy of anything great!
team 1671
Unread 19-02-2015, 08:50
Chris is me's Avatar
AKA: Pinecone
I'd love to talk with the inspector that decides that robots must have a minimum ground clearance to compete. It is odd because it doesn't make any sense at all, and it's never been a rule that you have to have a specific ground clearance. If you don't damage the actual field, you're fine. That's my 2c.
Unread 19-02-2015, 09:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The edges of the scoring platform are taped. The gear could pull up the tape under the right circumstance. But no more than a stalled wheel spinning on the taped seam.
