Go to Post It's all about inspiration until people start complaining about teams getting lucky schedules and seeding first. - Anupam Goli [more]
Unread 17-02-2015, 19:02
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
16 gauge solid core vs 14 gauge solid core (and Wago connectors)
Hi!
The Wago power connectors for the roboRIO and the PCM, for example, are spec'd for 16 gauge solid core. We happen to have used 14 gauge solid core. Probably a bit of a "push" for the Wago connectors.
But - will this cause a problem for us at inspection?
Thanks,
Martin
FRC Team 3045 ("SWAT")
Unread 17-02-2015, 19:08
FRC #3045
Re: 16 gauge solid core vs 14 gauge solid core (and Wago connectors)
A follow - up question - thoughts on the "inspection quality" vs "operational quality" - the latter being reliability on the field - of 16 AWG solid vs (tinned / untinned) 16 AWG stranded for the power connections from PDU to roboRIO and PCM...?
Unread 17-02-2015, 20:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Thumbs up Re: 16 gauge solid core vs 14 gauge solid core (and Wago connectors)
I doubt that you would be ruled non-compliant for too large a wire by the inspectors. It's certainly not on the checklist.
That said, if you're having real difficulty shoving the wire into the WAGO, that's probably a practical issue somewhere down the road - either this year, when you don't get as much contact as you should, or down the road when the "springs" in the WAGOs have experienced an inelastic shift.
Further, from a practical standpoint, our team has moved each year towards having a greater percentage of stranded vs solid wire on our robot. While stranded does not make those nice, neat right angle turns that IBE members want to see, stranded is much more amenable to continued functioning if the two ends move relative to one another, as happens all too often in robotics. In utterly practical terms, if you buy wire locally, get it from NAPA or Auto Zone or O'Reilly's or Pep Boys, not Home Depot or Lowe's. (though we do buy a lot of frame stock and miscellaneous hardware from both HD and Lowes, including some critical sensor mountings!)
Unread 17-02-2015, 23:32
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We have always been 100% stranded wire. I don't recommend any solid wire on the robot.
Avoid placing wire in openings that are too large. Here's why: last year I fixed probably a half dozen robots at regionals with cRIO crashes, due to wires too large for the connector.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 17-02-2015, 23:41
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by MrRoboSteve View Post
We have always been 100% stranded wire. I don't recommend any solid wire on the robot..
I second this - the wago-style connectors scare me if used with solid-core wire.
Unread 18-02-2015, 00:03
dtengineering's Avatar
AKA: Jason Brett
The only wiring rules I have seen involve colour and minimum gauge requirements.
There is a "catch all" category for anything that might create a safety hazard, but that is best reserved for situations where there actually is a safety hazard.
Jason
Unread 18-02-2015, 01:07
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
No argument, though I do admit to a bit of solid (22-ga) wire this year. Unfortunately, it's on the most-moving wire we have - going to the lift plate. Fortunately, it's just powering our "FunLights", so we won't lose any points if it breaks on us, just a bit of cool factor. Our "touch" sensors on the lift plate have stranded wires.
Unread 18-02-2015, 01:24
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
Solid wire is for houses, for a very good reason - metal fatigue. Since houses do not move or vibrate, solid is Vine. In machinery you almost never use solid as the vibrations will cause the wires to crack, the same as any metal that flexes. Robots vibrate more than most machines.
Unread 18-02-2015, 11:30
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Forgive my potential ignornace, but why not buy wire from Home Depot or Lowes? Is it just a pricing thing?
I guess we got lucky this year. We bought the plywood for the field elements and some wire from Home Depot this year, and got a discount because we were a local high school.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 18-02-2015, 11:46
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
The wire you get at Home Depot, Lowes, and most hardware stores is very stiff and hard to bend. The automotive supply stores generally stock wire that bends more easily, which makes it substantially easier to work with.
Unread 18-02-2015, 11:47
AKA: Steve Peterson
Wire has a couple attributes that make it better or worse for robot use:
type -- stranded vs solid
size -- gauge
insulation -- type
Auto supply houses stock wire that, in most cases, meets all three criteria. They aren't necessarily the cheapest places to buy wire, but they're accessible.
We sometimes use wire from Home Depot -- in particular we bought some stranded 12ga THHN this year, because we were there and needed it -- but the THHN insulation can be fairly stiff and difficult to work with. We probably should have gone and bought two rolls of 12ga wire at the auto parts store instead.
Unread 18-02-2015, 11:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Wire from Home Depot or Lowe's is mostly intended for houses, which, as noted earlier, don't move. Robots move...like cars...so buying wire intended for cars is a better idea.
Unread 18-02-2015, 17:09
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
From the screensteplive stuff - "To maximize pullout force and minimize connection resistance wires should not be tinned (and ideally not twisted) before inserting into the Wago connector."
If they are recommending not tinning the wire (which would make it solid) or twisting the wire (so it would not flatten out when the jaws close) one would think solid core is also not recommended. Right?
Unread 19-02-2015, 07:14
OK,
There is a few items here that can be answered.
1. Solid #14 for powering your devices will not violate any robot rules. That size of solid wire is more like a crowbar to the connectors though. What vibration the wire will receive will be transmitted into the connector. I am afraid early connector failure will be the result.
2. There are a variety of outlets for wire. We use MCM Electronics for a variety of wire, parts and tools. You can find them at http://www.mcmelectronics.com/
3. The Wago connectors do take solid wire but tinned, stranded wire is not the same. When you tin stranded wire, it does make the wire solid but in doing so, the outside strands cause a 'high spot' on the wire. These are what is contacting the the metal inside the connector and so all current must flow through these little spots on the outside of the wire. That increases the series resistance of the contact significantly. If you need to tin for making insertion easy, you can just add a little solder to the very end of the wire. The Wago connectors depend on this contact. If you really check into the specs, you will find that Wago downgrades the contact max current rating when used with solid wire simply due to the smaller contact area with solid wire. If you use the Wago ferrules, they are actually square in shape to maximize the contact area.
Unread 19-02-2015, 09:08
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
I was really hoping with the redesign of the control system we would get away from the troublesome wago connectors but instead we went to a smaller, more difficult to use size on things like the PCM and VRM. Why cant we just have screw terminals?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
