Go to Post You don't have enough money, you're under-staffed, you're not quite sure what the customer wants, requirements change, and they want it yesterday. - Kimmeh [more]
Unread 17-02-2015, 20:34
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Talon SRX PID Maximum Output
Is there a way to set a maximum output for the PID controller on the Talon SRX? I've searched through the CANTalon class as well as reading through the Software Reference manual and I've not found a way to limit the maximum throttle.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 17-02-2015, 20:42
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Talon SRX PID Maximum Output
See section 16.10 in the software manual. Is that what you are looking for?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 17-02-2015, 20:47
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
I had tried using ramp rate to help but I would rather be able to just hard-cap the throttle to a set maximum.
As a Mentor:
As a Driver:
Unread 18-02-2015, 01:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
What language are you using? NILabView, C++, Java, or Python?
Unread 18-02-2015, 05:41
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
We are using Java.
As a Mentor:
As a Driver:
Unread 19-02-2015, 09:10
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
I would like to know this too. It seems like a major oversight if it's not there. The WPILib PIDController class provides this functionality.
[2002-2005]: FLL Coach
[2007-2010]: Mentor FRC 241
[2011-current]: Lead Advisor
FRC 3467 - The Windham Windup // 3467 on TBA
Windup Robotics 4-H Club
Unread 19-02-2015, 09:38
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
See section 21.4 of the manual
http://content.vexrobotics.com/vexpr...l-20150201.pdf
This feature is not present in the current firmware.
