Go to Post "Rookie" just means you are new to the game, not that your team isn't as skilled as many already in the competition. - Bill Moore [more]
Unread 19-02-2015, 10:21
nfusselman1 nfusselman1 is offline
FRC #4076
nfusselman1 is an unknown quantity at this point
ERROR Loading Java to RoboRIO
We have 2 RodoRIO's and I had loaded java on one on about 1/18/2015 and it worked fine but now when I try to load it on the other one it does not let me load java. Does anyone know how to get around the Oracle update problem.
Lead Programmer (4076)
nfusselman1
Unread 19-02-2015, 10:25
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: ERROR Loading Java to RoboRIO
nfusselman1
The newest wpilib update fixes this, just make sure your wpilib is up to date and the java install tool should work.
Unread 19-02-2015, 10:27
ATannahill ATannahill is offline
AKA: Alex Tannahill
Are both roboRIOs set the same way?
Same team number, user account info has not been changed, JRE installed, etc.?
Can you post the error you get?
Edit: I thought you meant code, not the JRE.
Unread 19-02-2015, 10:29
FRC #4076
Ok I did not know they updated it.
Thanks
nfusselman1
