Go to Post Every team in FIRST can make this choice. Be positive, help others, and work like a maniac behind the scenes. This approach will bring you joy and satisfaction, whether you win or not. - OZ_341 [more]
Unread 19-02-2015, 11:12
bachster's Avatar
bachster bachster is offline
AKA: Katie Bach
FRC #2052 (KnightKrawler)
bachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant future
Re: LOOKING FOR FESTOS
Please keep in mind R66:
The only pneumatic system items permitted on 2015 FRC ROBOTS include the items listed below.
C. Solenoid valves with a maximum 1/8 in. NPT port diameter
It appears that the ebay link is a 1/4" port size which would not meet this rule.
If using non-KOP solenoids (or any non-KOP pneumatics components), please also be prepared to demonstrate with a manufacturer's spec sheet that they meet R64: "All pneumatic items must be COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi (with
the exception of R66-D)."
Automation Direct is a good source for pneumatics components, and they provide a $30 voucher to FRC teams (see the flyer in your KOP). You could also try directly ordering from Festo. Be sure to order the correct fittings to attach to your 1/4" tube if you don't have them already. 1/8" NPT is the thread size commonly found on the fittings supplied by FirstChoice/KOP. (NPT refers to the thread sizing standard. The actual OD of the fitting is more like 0.4", so it can be confusing). I think Festos are typically metric fittings. The ebay link looked like a BSPT (British) thread standard which is similar in size to NPT but not the same pitch.
Unread 19-02-2015, 12:28
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
They arent being used on the robot - they are being put on a test board
