Go to Post How else can I get my polar bear sized tub of Lard? - niklas674 [more]
Unread 19-02-2015, 12:01
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: Gyro's angle value going up
A "cheat" we have used in the past is a gyro reset button. That is, when we know we are at 0 degrees, we make the gyro equal zero.
Another more ambitious route is using vision to check the gyro. This was possible in 2011,12,13, and 14 due to static vision targets. All that was needed was a pose calculation.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 22-02-2015, 02:38
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by faust1706 View Post
A "cheat" we have used in the past is a gyro reset button. That is, when we know we are at 0 degrees, we make the gyro equal zero. .
While we have done this manually in the past, thanks for the reminder! We have "curb feelers" that help us square up with the scoring platforms. (See this link for photos. Maybe we can program an automatic reset to either 0 or 180 (whichever is closer to our current value) when both of them have found the ramp.
