Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 19-02-2015, 13:11
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: 16 gauge solid core vs 14 gauge solid core (and Wago connectors)
Originally Posted by Alan Anderson View Post
If you're having trouble using the Wago and Weidmuller connectors, it's probably because you're not using them properly. I find them simple, easy, and reliable. The only time I have any problems with them is when someone has bent, twisted, or otherwise mangled the wire after stripping it.
Preferring something else over the Wagos is a serious POV. We don't have too much trouble with Wago terminals but I'd feel better using screw terminals on the robots. My little company builds racks of equipment used on ships and planes for the Navy and Air Force. These are high vibration environments (like the robots) and Wago-like terminals are not allowed and for good reason. Tinning the wire, twisting the wire or using solid core wire is also not allowed but certain ferrules are allowed.
