Go to Post FIRST is not advanced shop class - KenWittlief [more]
Unread 19-02-2015, 19:58
VPpanther VPpanther is offline
FRC #4914
VPpanther is an unknown quantity at this point
Control system for Project robot?
Hi guys
Our team will be building a robot as a special project. But we cant afford to use a Roborio and motor controllers. high Performance isnt a huge issue, is there anyway we could have a properly functioning robot running off some sort of mini-computer like a arduino (with no motor controllers)? we actually have a Nvidia Jetson Tk1 could we use that?
Any help would be appreciated
Thank you
Unread 19-02-2015, 20:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Control system for Project robot?
Might depend on what kind of motors you are using to drive the robot. If they are big motors like the CIM, then you really do need speed controllers. If they are quite a bit smaller, you might be able to get away with using relays, but robot control will be difficult. Or you can use smaller less expensive motor controllers if you use smaller motors.
We've built some robots using vEx control systems, but you could use an arduino or any other controller that has enough outputs.
Unread 19-02-2015, 20:17
FRC #4914
thank you for the quick response,
we were hoping to build a full fledged chassis and robot with with atleast 6 CIM motors, what do you think would be the most cost effective solution to having these fully operational? could we buy 6 motor controllers and control them through a cheaper alternative to the roborio? or could we control them through a vex system?
our problem is a very tight budget.
Unread 19-02-2015, 20:20
You'll need motor controllers for the CIMs, but they can be controlled from a Vex system.
There are other control systems that can do the job, but you have to decide on your basic needs, e.g., wireless/tethered, joysticks you may want to use, etc.
Unread 19-02-2015, 20:35
FRC #4914
Well here is a list of the basics we'll need:
-operate at least 6 CIM motors
-wireless control
-be able to be controlled with joysticks and/or game pad
-operate several solenoids for pnematics
-operate a pneumatic pump
Pretty much a fully fledged FRC robot, our problem is that we can not afford a roborio which would cost us more than $500 CAD
Unread 19-02-2015, 22:31
Are you still using your cRIO from last year?
Unread 19-02-2015, 22:42
FRC #4914
The robot is actually to give away to a sponsor for use in tradeshows/events. Plus the cRIO from last year is part of our rookie robot that we are very proud of and we really don't want take it apart
Unread 19-02-2015, 22:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
An arduino with a wireless module is certainly up to this, understanding that you will need some real motor controllers for CIMs. It is also possible, depending on how many user controls you are planning to have, that you can use xBee as your wireless controller. This would let you make a small handheld controller with nothing but an xBEE, a battery, and the actual joysticks and buttons to control the robot. There are several xBee-to-Arduino adapter shields available. This is the basic model we used on our air cannon, which has four CIM-controlled talons on the drive system and two 3/4" pneumatic solenoid valves controlled from 5V relay modules controlled from an arduino with an xBee shield. We are also planning to add another talon-controlled and potentiometer-steered rotator for the guns next year. The hardware is all there, we just need to write the software.
Unread 19-02-2015, 23:31
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
I'm not entirely sure how the programming of this thing works, but it made a similar project of ours drive(with only 2 motors and no pneumatics though). Its got 6 channels for 6 motors.
http://www.andymark.com/product-p/am-2520.htm
You might want to look into HobbyKing for speedcontrollers and batteries and other alternate control systems stuff.
Unread 20-02-2015, 22:33
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
http://firstchoicebyandymark.com/fc15-019
Those are an option. But, you missed out on the best deal.
http://firstchoicebyandymark.com/fc15-049
Unread 21-02-2015, 10:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I must have been tired! That should read
four talon-controlled CIMs
Unread 21-02-2015, 16:23
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Personally I think Arduino powered robot controllers are the way to go...
We manufacture a low-cost easy to operate unit for just these purposes.
Gorgon Robot Controller
These units are programmed with Arduino and come with an easy-to-use driver station app that lets you control them with gamepads...just like the cRIO or RobotRIO.
These are also available through Andymark.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 21-02-2015, 16:24
AKA: Anthony Lapp
Of course if you want to just use an off-the-shelf Arduino you can get our driver station and libraries for free here....these let give you instant remote access to your Arduino for any robot project.
RobotOpen Hardware Agnostic Library
Anthony Lapp
RobotOpen
Unread 08-03-2015, 19:21
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
The Robot Open looks great. I have been looking at the hardware agnostic version. Will this allow me to use a Yun without an additional shield or digital sidecar?
Jim Smith
FLL Coach
FTC Coach 3721
FRC Mentor 1983
Unread 08-03-2015, 19:54
AKA: Anthony Lapp
Unfortunately the HA library currently only supports the Arduino Ethernet or Ethernet Shield.
That said...it works great and gives you a lot of flexibility!
Anthony Lapp
RobotOpen
