Re: belt drive VS chain drive
Well the robot is for a sponsor, they will take it to tradeshows and events to advertise their products. so the robot will most likely be facing clean level surfaces with the odd bump every now and again. upper elements wise it will have a humoniod type of structure with a head,shoulders, and arms so leaning toward precision. right now our dimensions are looking to be 34'' by 40'' and about 7-9 feet tall (the upper portion will be very light consisting of mostly sheet metal, so it will be very bottom heavy)
That's a bit better. 6WD colsons will probably work (and if it doesn't, you might be able to find some Lunacy wheels on AndyMark and use those--they're slick enough). That wide/long of a robot, you can probably get away with "flat" configuration, though I'd actually suggest using "mixed wheels", with at least one end being smoother/less "sticky" than the rest.
A couple of other items to bear in mind: I'd go single-speed transmissions, geared for a "reasonable" speed (say about 10 ft/second or less), but with two motors on each (in case of one failing). We're dealing with foot traffic here, so precision driving could be important. Also, some form of safety system should be on there, say a drivebase lockout (again because we're dealing with lots of people). I'd agree on the superstucture being more "precision" than not; after all you don't want it rocking onto some potential customer's head while under the control of your sponsor. |
oh okay, thanks for all the insight. I'll relay your suggestions to the team. much appreciated!
It's all about implementation. We had belts on our versachassis WCD last year and we switched to chain because the belts were breaking (they were waaay out of spec. load so that makes sense). The equivalent pitch diameter and width of 25 chain was much stronger and performed fine (24t 9mm belt vs 18t 25 chain).
My experience with chain and belt: Belt is lighter, do not stretch, are quieter, and more efficient than chain. Chains requires less precision, are much smaller for the same strength, are much easier to source (especially up here in Canada), can be easily modified to different lengths, have many more available sprocket sizes, you can easily make any sprocket you can't source if you have a CNC mill, and chains can be easily bolted to for a function. We like the compactness and general ease of use of chain so we decided to use it over belt this year. Last edited by Scott Kozutsky : 19-02-2015 at 23:24. |
Belt has a much better damping effect than chain. Try spinning a chain system and a belt system at a high rate of speed.
Belt is easier to keep aligned over a long distance between axles. |
#7
Check out this -
http://www.chiefdelphi.com/media/papers/2216 and this - http://www.chiefdelphi.com/media/papers/2246 Last edited by Chris Fultz : 23-02-2015 at 22:19. |
#8
