Go to Post I would like to extend my deepest, most sincere thanks to the GDC, for bringing alliances to us in 1999. - Ken Patton [more]
Unread 18-02-2015, 16:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Encoder
Originally Posted by nickmcski View Post
We wired the cables like so:
(This image is not mine, I just found it online)
The encoders should be connected to DIOs, not PWM ports!
Unread 18-02-2015, 16:24
Re: Encoder
Yes, I agree, that diagram can be misleading out of context. The "PWM" in the diagram refers to the use of PWM cable/connectors.
In context (i.e. on the web page where the diagram came from) it explicitly says to connect the cable to DIO ports.
Unread 18-02-2015, 17:41
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Encoder
is there any reason why i wouldnt get an accurate reading from the encoders?
Unread 18-02-2015, 17:51
Re: Encoder
To avoid having two separate conversations about two unrelated questions in the same thread, it would be best if you started a new thread if your question is not related to the OP's question; and provide more detail about the problem you are experiencing.
Unread 19-02-2015, 15:28
NathanCJohnson's Avatar
NathanCJohnson NathanCJohnson is offline
FRC #5517 (District 5517 The Engineers on Fire)
Team Role: Driver
Rookie Year: 2015
NathanCJohnson is an unknown quantity at this point
Re: Encoder
These are the encoders our team purchased http://www.andymark.com/product-p/am-0180.htm and they are working extremely well for us. One thing we want to try is wiring them directly up to our talons (You can only do this if you have the talon SRX's).
If you cant wire them up to the talons then wire them up to the roboRIO, our team accomplished this by cutting up 2 unneeded PWM cables. We wired the cables like so:
Then we programmed them link this
	Encoder encoderleft; //Declare the encoders so they are accessible in all methods
	Encoder encoderright;
	public void robotInit() {
		encoderleft = new Encoder(0, 1); //Initalize the encoder, A channel is plugged into DIO 0, B channel DIO 1.
		encoderright = new Encoder(2, 3);
		encoderleft.setDistancePerPulse(0.11); //did some math to calculate that for 1 pulse the robot moved 0.11 of an inch (Will be different for other robots)
		encoderright.setDistancePerPulse(0.11);
	public void autonomousPeriodic() {
		double distance = (encoderleft.getDistance() + encoderright.getDistance()) /2; //Find the distance robot has travled based off of the average of the 2 encoders.
		//Code to make your robot move off of the encoder values here
Does that encoder work with the 2015 KOP chassis gearboxes? The video tutorial on the item page shows a different gearbox, so I just want to make sure it works with the KOP one.
We should have added encoders a while ago before bag & tag, but since we didn't we will be adding them during the 6-hour robot access period the week of our first district event. Currently our autonomous modes are based on a timer which isn't very accurate or predictable.
Unread 19-02-2015, 15:56
Re: Encoder
What kind of drivetrain do you have?
Unread 19-02-2015, 16:12
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Encoder
Our team didn't get the KOP drive train but on andymarks website they say that the KOP gearbox is compatible with the type of encoders I linked.
Here is the information about the gear box if you want to look at its specification for the encoders http://www.andymark.com/product-p/am-2598.htm
Unread 19-02-2015, 17:41
Head programmer
Re: Encoder
yeah are they compatible? my team ran into the same problem...they are mounted but it seems they are not giving us a very reliable rate
Unread 19-02-2015, 21:55
Team Role: Driver
Rookie Year: 2015
Re: Encoder
We're using the one that came in the Kit of Parts (http://www.andymark.com/AM14U2-p/am-14u2.htm). But we're using 6" traction wheels in the front and 6" omniwheels in the back (the middle wheels are the 4" wheels that came with the KOP drivetrain).
Unread 19-02-2015, 21:59
Team Role: Driver
Rookie Year: 2015
Re: Encoder
Alright, thanks! I think we'll order a couple (hopefully they'll come fast enough) and we can add them during the robot access period and get autonomous working with them.
Unread 19-02-2015, 22:10
Re: Encoder
Are you powering all 6 wheels? How?
Unread 19-02-2015, 23:53
Team Role: Driver
Rookie Year: 2015
Re: Encoder
Two CIM motors power the gearbox which moves the middle wheel. The front and rear wheels are powered by the middle wheel with belts. We use tank drive to actually drive and steer it.
Unread 19-02-2015, 23:56
Re: Encoder
You said the middle wheels are 4" and the front/back are 6". Have you geared them in the proper 6:4 ratio so they are going the same tangential speed?
Unread 22-02-2015, 01:32
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Encoder
Unless the chassis has been modified (drilled more holes) it isn't necessary. The center axle on the AM14U2 is only dropped 1/8". Since the corner wheels are 2" larger diameter, the 4" center wheels float 7/8" off the carpet. In effect, the 4" wheels are just a spacer for the belt sheaves.
We did something similar with our H-drive, though since we used 4" wheels on the corners, we cut the rubber off the center wheels so they would float.
Unread 22-02-2015, 08:52
Re: Encoder
Except when going over the platform.
