Go to Post The only thing more dangerous than a Programmer with a screwdriver is a Hardware Designer with the root password... - kmcclary [more]
Unread 19-02-2015, 23:38
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
60 second set-up / pack-up time?
In the rules, it says that drive teams must set up their robots from transport configuration before each match and pack it back into transport configuration quickly. "60 seconds" is given as a "guideline."
With all the very creative/innovative/complicated robots we are seeing in reveal videos, I am starting to wonder how many of them are going to be able to do that? Do we have any idea how strictly referees are going call the 60-second guideline? I know we made some design decisions with that guideline in mind, but I wonder if some others did not? Or at least hope to abide by the time limit rather loosely?
Unread 19-02-2015, 23:45
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: 60 second set-up / pack-up time?
We've got a fairly complicated transport configuration that takes some practice to get done on time.
It's part of our driver practice.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 20-02-2015, 00:22
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Ours is a decent job, hooking up Anderson Powerpoles, adding bolts, quick release pins, and connecting pneumatic tubing. We developed a procedure for the drive-team to follow, all 4 drive team members are doing something.
One does the drivestation and selects autonomous, second, attaches the left side of our intake, third does right side. This includes one Powerpole and one pneumatic tube each, in addition to 4 bolts and 4 quick release pins.
The coach runs a quick checklist at the end to make sure everything is done. With a few practice runs, we can do this in 48 seconds.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 20-02-2015, 00:23
Gregor's Avatar
How are you connecting tubing with pressure in the system?
<Since 2011
Unread 20-02-2015, 00:25
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Ours is just six pins to install. We managed to keep all powered components inside our main robot body, but we definitely didn't take advantage of the relaxed rules as much as many have.
Unread 20-02-2015, 00:28
Sohaib's Avatar
AKA: Sohaib Nadeem
The air to the pistons on the intake is stopped by a butterfly valve. Once the tubing is connected to its connectors, the butterfly valve is opened.
The system is also charged with this valve closed.
We're contemplating just having long enough tubing so that we can put it into the transport configuration without the need of the butterfly valve which likes to leak.
2014 Season:
- Drive Coach
2015 Season:
- Driver
2016 Season:
- Driver
Unread 20-02-2015, 00:39
Gregor's Avatar
It sounds like you're violating R78A
Originally Posted by R78
Any pressure vent plug must be:
A. connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored
pressure in a reasonable amount of time
<Since 2011
Unread 20-02-2015, 00:43
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I'd imagine the teams that came up with the most creative use of transport configuration took into account setup time.
That being said, for us all we have to do is place two quick release pins in our stacker mechanism once on the field.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 20-02-2015, 00:47
dtengineering's Avatar
AKA: Jason Brett
Good point... although I wouldn't necessarily take this as a "pressure vent valve", so long as there was a real "pressure vent valve" located elsewhere on the robot. I'd suggest that "pressure vent" describes the function of the valve, and the valve described here is clearly not designed to vent pressure at the end of the match.
So not that I think this setup should be a problem, but the event it is they could simply replace their ball valve with a single-acting solenoid valve and it would be fine.
Jason
P.S. I have no doubt, whatsoever, that teams with the technical ability to generate some of these amazing multi-part designs, will drill, drill and drill to the point where they are quicker at setup than many teams with simpler tasks to perform.
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
For Transport Configuration, it's two bolts and two pins. If we happen to find a door that we're too tall at, it's two bolts and two cables (1 USB, 1 powerpole).
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 20-02-2015, 00:48
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Quick release pins are the bomb.net
Drop in the zone, use the "super-square" I need to make this weekend, drop and lock the back arms, flip the front arms. It can probably be done in 60 seconds. Probably.
Unread 20-02-2015, 00:49
Gregor's Avatar
Jason
Wouldn't that mean that the main pressure vent valve wouldn't always be able to vent all air pressure?
<Since 2011
Unread 20-02-2015, 01:06
AKA: Jason Brett
I agree... but with their butterfly valve open (as it would be during the match) it would essentially be transparent to the rest of the system and the main pressure vent valve would be able to vent all the air pressure.
The simple fact that two FRC veterans see this from different views, however, suggests the team would be wise to make a quick Q&A so they'll know if they need a different solution at their regional.
Jason
Unread 20-02-2015, 01:15
Sohaib's Avatar
AKA: Sohaib Nadeem
Jason
We have another option should the current setup be deemed illegal.
2014 Season:
- Drive Coach
2015 Season:
- Driver
2016 Season:
- Driver
Unread 20-02-2015, 01:20
Gregor's Avatar
Certainly. Can someone with Q&A access ask that please?
<Since 2011
