Go to Post I am the person I am because I have come to accept the mistakes I have made, not because I try to change them. - IronicDeadBird [more]
Unread 09-03-2003, 15:12
Jared Russell's Avatar
Taking a year (mostly) off
5VDC from Gyro - 64 or 75 deg/s?
I've seen spec sheets that specify the maximum signal from the gyro (5VDC, or 254 in PBASIC) correlates with either 64 deg/s and 75 deg/s...which is it?
Thanks.
Unread 09-03-2003, 15:13
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Last year's gyro chip was rated at 64deg/sec, but this year's is rated at 75deg/sec.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 09-03-2003, 20:17
It's rated at 75 deg/sec, but the range of voltage is 0.25 V off each rail (1/4 to 4-3/4 V). It's 27 mV / deg/sec, but remember the resolution on the RC is 20 mV at best, about 0.75 deg/sec / count.
Usage of the gyro jon virgi General Forum 37 09-06-2003 11:57
gyro code odin892 Programming 2 08-04-2003 14:50
gyro odin892 Programming 0 08-04-2003 09:59
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
