| Thread Tools |
Rating:
Display Modes |
#16
Re: 60 second set-up / pack-up time?
Very simply put, ball and butterfly valves are not on the list of allowed pneumatic components, therefore they are not allowed.
The one exception is the one vent plug valve. |
#17
It has always been in the rules that delaying the competition in one way or another with result in penalties. It's in the rules that delaying a match AT ITS CONCLUSION (i.e. delaying field reset) may result in a yellow card. I would be surprised if delaying the start of a match didn't have similar results. The referees have a schedule to maintain. Quick match cycles make for a much smoother event. No one, be it teams, volunteers or spectators, want to sit there and watch you assemble your robot. If you have a 62 second set-up time I would be expecting referees to be breathing down your neck, but remember, you are keeping people waiting. Personally, we did everything we could to fit in the transport config. Our current bagged robot fits in the transport configuration with no assembly required. It's faster, and we we don't need to worry about forgetting to do anything aside from turn the robot on (which, historically, I have a bad track record with anyway). When we get to FLR, I dunno. Maybe that'll change. But sizing and set-up requirements I believe should have been part of every team's design choice. |
#18
we're completely within the parameters, no set up needed....but listening to everyone, sounds like we did something wrong
#20
We actually touched on this subject briefly in a ref call with our event's head ref. I know my head ref likes to give the benefit of the doubt and has said there will not be stop watches. 60 seconds is a guideline. I think what we'll be looking at more than anything is not being on the field building your robot for 60 seconds longer than everyone else.
ie: teams 1, 2, 3, 4, 5 have assembled their robot and gone to their driver's station, but team 6 takes 2 minutes longer when they started at the same time. It's going to be a tough call, nobody wants to give a YC for that. I don't think there's been a YC given at our regional for delay of game that I can remember. Oh, and I think we are still sticking to 6 or 7 minute turn arounds, so good luck to everyone! ![]() |
#21
I'm with Gregor on this one and would suggest that you guys install your "other option". Of Course a Q&A would really help here just to be sure.
#22
Instead, use a standard shop compressor quick connect fitting. It's a standard fitting, so it's a legal part, and when disconnected does not leak any air. |
#23
The big issue isn't strictly ruling on the 60 second time... it's on maintaining the pace and turn around time of the matches. Imagine, if you would, everyone taking an extra 15 seconds. With a 60 team event and every team getting 10 qual matches, that's 100 matches, or an extra 1500 seconds - almost half an hour added to the day. The head ref, FTA, field reset, and others around the field are going to be doing everything they can to avoid having that happen.
#24
We originally felt similarly, until re-reading the rules. We determined that the second valve would fall under R66-F, as a flow control valve.
Why don't you just install your cylinders downstream from a solenoid that is normally closed? |
#26
The head ref may not be watching the clock, but your FTA will call you out on it (and talk to the head ref) if it is causing a problem.
They will also be more strict as the regional progresses- you will probably have a bit of leeway on Thursday and going into Friday because the FTA(A) will be busy getting teams connected and making sure the field is in working order. Those problems start to go away on Friday though. If you are still putting your robot together but all the robots are connected to the field and we are ready to go, then I will probably be talking to you about your setup time. |
#27
It bothers me when the field can't stay on schedule. It would bother me even more if it was team set up that was delaying the schedule. If a team consistently takes longer than 60 seconds to set up, I guarantee they will be moved down on our pick list. I have seen penalties in elims for sillier things than this. It's not worth it to us to risk a yellow card every match because our partner can't set up quickly.
#28
When using a "flow control valve" as a "blocking valve" it ceases being a "flow control valve" and is no longer legal. While not even predicting if the GDC would answer a question about this, the logic is similar to what they used in the past. Using a quick connect fitting is a good idea, but they are essential check valves which are not legal. Of course if it is considered to be an integral part of an legally allowed connecting fitting... |
#29
how about leaving the cylinder connected to the tubes, and have a quick mounting system for it? with pins and clips, or something
#30
We had a similar pneumatic lockout problem. We solved it with a single acting solenoid. When the robot is disabled it "defaults" to a closed loop and vents the lines that run to the solenoids that run the cylinders, allowing us to disconnect the lines. When the robot is enabled, we enable the solenoid and it sends air to the system that has been attached.
