functions for auto
Hey guys I just finished my autonomous program on bag night and the next day realised how long and messy it was. So I got some help and made functions but I can't test them
. So if anyone is able to help me here's the github link https://github.com/curtis0gj/5033-2014-15?files=1. |
Re: functions for auto
FYI you can build them to search for syntax errors... like this
private static void wait(Robot r, double waittime) {
while (true) {
if (!.risAutonomous() || !r.isEnabled()) return;
r.Timer.delay(waittime); //r or just timer?
return;
private static void reset(Robot r) {
passing in Robot for everything is ugh-ly. just make Robot a singleton... or use a static initializer Code:
while (true) {
double distance = r.encoder.get();
double angle = r.gyro.getAngle();
if (!r.isAutonomous() || !r.isEnabled()) return;
r.robot.drive(-0.25, angle * r.Kp);
//r.robot.drive(-0.40, 0);
if (distance < -d) {
reset(r);
return;
r.robot.drive(-.40, -1) Code:
Boolean maxarmlimit = r.limit4.get(); Code:
r.armmotor.set(Defines.ARM_SPEED); r.leftarmwheel.set(Relay.Value.kForward); r.rightarmwheel.set(Relay.Value.kReverse); Code:
if (angle > deg) {
r.robot.drive(-.40, -1); your "turn" and "turn2" functions are quite ineffective, basic angle averaging schemes should be used other than that I'm losing my focus, but there are alot more issues Last edited by Arhowk : 02-20-2015 at 12:19 PM. |
should distance be an int or a double and how should I add the periodic timer?
for distance, i usually go with doubles for most things so I don't accidentally mess data up with division. don't know what the second thing you asked is in reference to. If it's the closed loop, than just do a Timer.delay(0.02) (20ms, standard 50hz operating cycle) inside the while(true) loop |
https://github.com/curtis0gj/5033-20...ster/Auto.java |
#7
Preferably it would be the last line (with it at the first, theres a 20ms delay before any actions are performed)
Your indenting for everything after "wait" is now wrong AUTOS should not be capitalized (and should be descriptive: "AutonMode", "SelectedAutonMode", "AutonEnum", etc) turn and turn2 still need to be turned into feedback loops but for now rename them to turnLeft and turnRight and make one function- turn- that if gyro < desired than turnLeft(angle) else turnRight(angle) capitalization schemes are wrong in Robot.java (http://java.about.com/od/javasyntax/...onventions.htm) Code:
if (autoMethod == Defines.AUTOS.AUTO_ONE) {
return;
} else if (autoMethod == Defines.AUTOS.AUTO_MOVE) {
return;
} else if (autoMethod == Defines.AUTOS.AUTO_TWORED) {
return;
} else if (autoMethod == Defines.AUTOS.AUTO_TWOBLUE) {
return;
Why is your wait function inside of a while(true) loop? Last edited by Arhowk : 02-20-2015 at 07:09 PM. |
#8
public static void turn(Robot r, double deg) {
while (true) {
if(angle < 70) {
turnRight(r, 70);
} else {
turnLeft(r, -70);
reset(r);
break;
#9
if(deg < gyro.getAngle()){ //this is not right, need to have a function to handle rollovers
//example for such a function: if Math.abs(deg-gyro.getAngle()) < 90 || Math.abs(deg-gyro.getAngle()) > 270
//i dont know, just thinking to myself. see here for further instructions -> http://stackoverflow.com/questions/1878907/the-smallest-difference-between-2-angles
turnLeft(r,deg);
}else{
turnRight(r,deg);
public static void turnRight(Robot r, double deg){
while(true){
//turn right
if(distanceBetweenAngles(getGyro(),deg) <= MAX_ROTATE_ERROR){
return; //or break; whatever
Timer.delay(0.02);
E/ misunderstood the point of the code, fixed. Last edited by Arhowk : 02-20-2015 at 08:27 PM. |
#10
note that I edited that post like 5 times. Anyway, heres a (maybe) working function Code:
public static double angleError(double setpointDegressZeroToThreeSixty, double experimentalDegrees){
double err = setpointDegressZeroToThreeSixty - experimentalDegrees; //0 360
if(err < -180){
err += 360;
}else if(err > 180){
err -= 360;
return err;
double kp_rotate = 0.01;
double MAX_ERROR = 5;
public static void turn(double deg){
while(true){
double deltaAngle = angleError(deg, gyro.getAngle());
if(Math.abs(deg-deltaAngle) < MAX_ERROR){
break;
}else{
robot.drive(0, deltaAngle*kp_rotate); //drive taking a move and a rotate value
Timer.delay(0.02);
#12
The new turn function does, yes, since the error will be positive or negative depending on where the setpoint is in comparison to the experimental and thus doesn't need seperate cases depending on left or right.
#14
Should I change the static voids to private and add Robot r. Also I wanted to know how I can make the wait function work so the robot waits between certain functions.
#15
apologies, wrapped up in poe.
Timer.delay will wait the desired time. For the new loops, they automatically wait untill finished so this isn't needed. If you wanted to add an extra wait, just throw in a Timer.delay() before turn, drive, etc. calls |
