| Thread Tools |
Rating:
Display Modes |
#31
Re: 60 second set-up / pack-up time?
Our team requires four pins and two bolts. Attaches our arms to the main gripper plate. Everything else is well contained within the robot. |
#32
If you used a ball shut off valve, then it would NOT be legal. The rules are very specific on this. |
#34
Doesnt seem like this would be allowed per G14 and the definition of tethering given: Quote:
How did you come up with this? It sounds to me like they are simply plugging in the wiring for a motor, which is on a mechanism that gets removed after the match and reinstalled before the next match.
#37
Just dont want to see anyone disappointed when they try to go out on/off the field with a powergun and told they are not allowed to. |
#38
It seems obvious to me that they are just using the Powerpoles to make an electrical connection between the robot and an actuator on the removeable appendage. I make that inference because the TechnoKats robot has exactly the same thing.
#39
This was discussed this season by some of the LRI's R66 is very clear.
Check valves are also illegal. Q134 Does allow for pluming a solenoid's outputs into a another's input, but warns that the vent plug must always be able to dump all air. I'm not thinking of a simple way to do this. It might be possible for a single solenoid to switch states when it loses pilot pressure and vent the upstream air regardless of state but I'm not sure about that and would need to test it. Using a needle valve to stop flow seems legal to me at the moment, and I would pass it at an event I was inspecting right now, any other type of valve would be illegal. That could easily change. |
#40
As a RI and a Ref, what I would do is: Towards the end of practice matches, make a comment to the Driving Team. (think of this as your first warning). During Qualification matches, make a comment to the LRI and suggest that the robot be reinspected for "Mechanical, End of Match" on the Inspection Check List. The LRI watches matches, so I'm sure it would not take much convincing. (this is your second warning). The Refs usually eat lunch together and discuss stuff. I'm sure offending robots would be mentioned. If anything happens after this point, the robot has been warned. |
#42
That being said, the seats on those valves generally are not designed for repeated shutoffs and will generally start to leak. Just because you can do something doesn't mean that you should. |
#43
I am highlighting ONE vent plug since it seems to be pretty important in its distinction as R67D says, "At least one pressure vent plug," R78, "Any pressure vent plug must be:," R78A, "connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure in a reasonable amount of time". If there is a piece in the system that "can" prevent this, then I would think real hard of another way to accomplish the task. As FTAA, I have to remind way too many teams during an event as to why their robot doesn't seem to have a working RSL light, or any light for that matter. It is AMAZING how many bot loaders forget to squeeze the breaker to actually power on the thing. That alone would make me say no way to a manual valve in the pneumatic system that must be physically opened when they get to the field if it has a chance of not allowing full venting from ONE plug activation. Haven't taken my RI cert test yet for this year, but I know how I would answer if this question comes up in it. |
#44
This means that the air has two pathways inside the valve, flow in one direction is restricted through the adjustable needle valve. In the opposite flow direction, it can either travel back through the needle, or through a separate internal check valve, which is not restricted. In the case of using one of these flow controls as suggested in this thread, at no time would the needle valve isolate a portion of the circuit, or prevent complete draining of all pressure when the one relief valve is opened. The check valve integral to the flow control would always allow pressure to be drained completely, even if the needle is fully closed. This is fundamentally different from the use of a ball valve. As Daniel suggested, you may find the needle valve starts to leak after repeated shut-offs. You will also likely find your one-touch fittings leaking after several re-connections, as they are only good for a dozen or so insertions before the tube needs to be cut shorter. I would also argue that there are better legal ways to accomplish this (such as a single-acting valve at this connection). A main concern I would have with using a flow control valve is that the team should always drain their pressure completely after the match, before attempting to disconnect this mechanism (regardless of closing the needle valve). |
