Go to Post Robots will consume you if you are not careful. - JohnBoucher [more]
Unread 20-02-2015, 12:59
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: 60 second set-up / pack-up time?
Originally Posted by Lil' Lavery View Post
The portion being isolated is exposed to atmosphere while in transport configuration. No pressure is being stored there. The "pressure vent plug" will still be capable of releasing all pressure from the pneumatic system.
At the end of the match, the team member responsible for activating ONE vent plug does so and backs off without touching anything else. Is there ANY position possible for this butterfly valve to be in that causes all of the air in the system to not be vented when opening ONE vent plug? It doesn't matter what the transport configuration is, it matters if it is possible at all on the field when ONE vent plug operation is performed. Stuff happens during a match that can cause unintended operation of components.
I am highlighting ONE vent plug since it seems to be pretty important in its distinction as R67D says, "At least one pressure vent plug," R78, "Any pressure vent plug must be:," R78A, "connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure in a reasonable amount of time". If there is a piece in the system that "can" prevent this, then I would think real hard of another way to accomplish the task.
As FTAA, I have to remind way too many teams during an event as to why their robot doesn't seem to have a working RSL light, or any light for that matter. It is AMAZING how many bot loaders forget to squeeze the breaker to actually power on the thing. That alone would make me say no way to a manual valve in the pneumatic system that must be physically opened when they get to the field if it has a chance of not allowing full venting from ONE plug activation. Haven't taken my RI cert test yet for this year, but I know how I would answer if this question comes up in it.
Nate
