Go to Post FIRST is like pizza--you and I might prefer different toppings, but there's no wrong way to do it. - Billfred [more]
Unread 20-02-2015, 16:30
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
.NET Framework 4.5 Issue
I am trying to install this so I can use the driver system, and this is the error message that comes up. Can anyone help me?
OS Version = 6.1.7601, SP = 1.0, Platform 2, Service Pack 1
OS Description = Windows 7 - x64 Home Premium Edition Service Pack 1
MSI = 5.0.7601.18637
Windows version = amd64_windowsfoundation_31bf3856ad364e35_6.1.7601. 17514_none_615fdfe2a739474c.manifest
Windows servicing = 6.1.7601.17592
CommandLine = C:\c4cbd044004238cfc6b5139558\\Setup.exe /x86 /x64 /web
TimeZone = Central Standard Time
Initial LCID = 1033
Using Simultaneous Download and Install mechanism
Operation: Installing
Package Name = Microsoft .NET Framework 4.5 Setup
Package Version = 4.5.50709
User Experience Data Collection Policy: Disabled
Number of applicable items: 9
Exe (C:\c4cbd044004238cfc6b5139558\SetupUtility.exe) succeeded.
Exe Log File: dd_SetupUtility.txt
ServiceControl operation succeeded!
MSI (C:\c4cbd044004238cfc6b5139558\netfx_Full_x64.msi) Installation failed. Msi Log: Microsoft .NET Framework 4.5 Setup_20150220_152229737-MSI_netfx_Full_x64.msi.txt
Final Result: Installation failed with error code: (0x80070643), "Fatal error during installation. " (Elapsed time: 0 00:01:19).
Unread 20-02-2015, 17:19
AdamStockton AdamStockton is offline
Scoutmaster
FRC #1507 (Warlocks)
AdamStockton will become famous soon enough
Re: .NET Framework 4.5 Issue
What specifically are you trying to install? If you are trying to install an application that is also trying to install the .NET framework, you should try and install .NET separately.
You can download the .NET framework 4.5 from Microsoft here:
http://www.microsoft.com/en-us/downl....aspx?id=30653
Mentor Team 1507 (2013 - Present):
1 Regional Win - FLR 2014
1 Regional Finalist - Buckeye 2013
Student Team 1507 (2009 - 2012):
1 Division Win - Newton 2009
3 Regional Wins - FLR 2009, FLR 2012, Buckeye 2012
1 Regional Finalist - Pittsburgh 2011
Unread 20-02-2015, 17:23
FRC2501's Avatar
The driver system requires the .NET framework, we tried downloading it from the link above and it does not install correctly.
Unread 20-02-2015, 17:27
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
A quick Google of the error code found this Microsoft KnowledgeBase article:
http://support.microsoft.com/kb/976982
It appears that MSI is interfering with it.
Hope this helps!
Unread 20-02-2015, 17:43
Scoutmaster
I've never had this issue with .NET before, but it might be worth looking to see if you have any additional versions of .NET installed (3.5 is built into Windows 7). It's possible that you have a corrupted install of .NET, which is preventing you from installing the new one.
Search "programs and features" in the start menu and click enter. Scroll down to Microsoft .NET Framework and see what versions you have installed. If you have an existing copy of 4 or 4.5, try uninstalling and re-installing it.
Hopefully that works (or one of the other suggested fixes above). Otherwise, you might have a bigger issue at hand.
Unread 24-02-2015, 17:01
FRC2501's Avatar
So far none of these solutions have worked, even Microsoft's official "Fix It" tool hasn't fixed it, we have decided to try and reinstall Windows from the factory CDs (The kid's only had windows for 2 weeks and has only installed Minecraft and Chrome).
Unread 24-02-2015, 17:34
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Give the offline installer a shot first:
.net 4.5:
http://www.microsoft.com/en-us/downl....aspx?id=40779
or
.net 4.5.2:
http://www.microsoft.com/en-us/downl....aspx?id=42642
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
