Go to Post I personally think mentors should sit behind two-way mirrors and hold a kill switch for all power tools. ;) - SenorZ [more]
Unread 20-02-2015, 18:53
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: functions for auto
Originally Posted by Arhowk View Post
don't double post, use the edit button.
for distance, i usually go with doubles for most things so I don't accidentally mess data up with division.
don't know what the second thing you asked is in reference to. If it's the closed loop, than just do a Timer.delay(0.02) (20ms, standard 50hz operating cycle) inside the while(true) loop
Alright I added in some delays inside the while(true) loop. I just put the delay as the first line in the loop I don't know if it matters.
https://github.com/curtis0gj/5033-20...ster/Auto.java
Unread 20-02-2015, 19:05
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Preferably it would be the last line (with it at the first, theres a 20ms delay before any actions are performed)
Your indenting for everything after "wait" is now wrong
AUTOS should not be capitalized (and should be descriptive: "AutonMode", "SelectedAutonMode", "AutonEnum", etc)
turn and turn2 still need to be turned into feedback loops but for now rename them to turnLeft and turnRight and make one function- turn- that if gyro < desired than turnLeft(angle) else turnRight(angle)
capitalization schemes are wrong in Robot.java (http://java.about.com/od/javasyntax/...onventions.htm)
		if (autoMethod == Defines.AUTOS.AUTO_ONE) {
			return;
		} else if (autoMethod == Defines.AUTOS.AUTO_MOVE) {
			return;
		} else if (autoMethod == Defines.AUTOS.AUTO_TWORED) {
			return;
		} else if (autoMethod == Defines.AUTOS.AUTO_TWOBLUE) {
			return;
this block of code is rather... erm...
Why is your wait function inside of a while(true) loop?
Unread 20-02-2015, 19:55
Rookie Year: 2015
			return;
			return;
			return;
			return;
lol I did a very lousy job of naming things, sorry for that and I will change the names to be more descriptive and properly cased. Anyway how can I get the waits to work again? This is the function,
	public static void turn(Robot r, double deg) {
		while (true) {
			double angle = r.gyro.getAngle();
			if (!r.isAutonomous() || !r.isEnabled()) return;
			if(angle < 70) {
				turnRight(r, 70);
			} else {
				turnLeft(r, -70);
				reset(r);
				break;
I'm not sure how to program it, sorry I'm still fairly new to programming.
Unread 20-02-2015, 20:20
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
here's what I'd do
   if(deg < gyro.getAngle()){ //this is not right, need to have a function to handle rollovers
   //example for such a function: if Math.abs(deg-gyro.getAngle()) < 90 || Math.abs(deg-gyro.getAngle()) > 270
   //i dont know, just thinking to myself. see here for further instructions -> http://stackoverflow.com/questions/1878907/the-smallest-difference-between-2-angles
         turnLeft(r,deg);
   }else{
         turnRight(r,deg);
public static void turnRight(Robot r, double deg){
   while(true){
       //turn right
       if(distanceBetweenAngles(getGyro(),deg) <= MAX_ROTATE_ERROR){
           return; //or break; whatever
       Timer.delay(0.02);
except without the broken formatting since I made that in this text editor and not a code editor
E/ misunderstood the point of the code, fixed.
Unread 20-02-2015, 20:28
Rookie Year: 2015
here's what I'd do
         turnLeft(r,deg);
   }else{
         turnRight(r,deg);
So what will this whole function be used for calculating turns?
Unread 20-02-2015, 20:32
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
hm?
note that I edited that post like 5 times.
Anyway, heres a (maybe) working function
public static double angleError(double setpointDegressZeroToThreeSixty, double experimentalDegrees){
    double err = setpointDegressZeroToThreeSixty - experimentalDegrees; //0 360
    if(err < -180){
        err += 360;
    }else if(err > 180){
	err -= 360;
    return err;
double kp_rotate = 0.01;
double MAX_ERROR = 5;
public static void turn(double deg){
    while(true){
        double deltaAngle = angleError(deg, gyro.getAngle());
        if(Math.abs(deg-deltaAngle) < MAX_ERROR){
            break;
        }else{
            robot.drive(0, deltaAngle*kp_rotate); //drive taking a move and a rotate value
        Timer.delay(0.02);
Unread 20-02-2015, 20:38
Rookie Year: 2015
hm?
    if(err < -180){
        err += 360;
	err -= 360;
    return err;
    while(true){
            break;
        }else{
        Timer.delay(0.02);
Does this turn function replace left turn and right turn?
Unread 20-02-2015, 20:39
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
The new turn function does, yes, since the error will be positive or negative depending on where the setpoint is in comparison to the experimental and thus doesn't need seperate cases depending on left or right.
Unread 20-02-2015, 20:51
Rookie Year: 2015
Should I change the static voids to private and add Robot r. Also I wanted to know how I can make the wait function work so the robot waits between certain functions.
Unread 20-02-2015, 22:58
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
apologies, wrapped up in poe.
For now, yeah. End game shouldn't have that "Robot r" parameter
hm?
Timer.delay will wait the desired time. For the new loops, they automatically wait untill finished so this isn't needed. If you wanted to add an extra wait, just throw in a Timer.delay() before turn, drive, etc. calls
Unread 20-02-2015, 23:01
Rookie Year: 2015
hm?
Alright thanks, to replace the Robot r parameter could I extend my public class auto to robot or is there another way to do it?
Unread 20-02-2015, 23:08
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Something like this
static Robot r
public static void setRobot(Robot rob){
    r = rob;
//in Robot.java
AutonManager.setRobot(this);
or
Robot robot
public AutonManager(Robot r){
    this.robot =r;
//in Robot.java
AutonManager autonManager;
public void robotInit(){
    autonManager = new AutonManager(this);
