#16
Re: Encoder
The encoders should be connected to DIOs, not PWM ports!
#17
Re: Encoder
Yes, I agree, that diagram can be misleading out of context. The "PWM" in the diagram refers to the use of PWM cable/connectors.
In context (i.e. on the web page where the diagram came from) it explicitly says to connect the cable to DIO ports. |
#18
Re: Encoder
is there any reason why i wouldnt get an accurate reading from the encoders?
#19
Re: Encoder
Re: Encoder
We should have added encoders a while ago before bag & tag, but since we didn't we will be adding them during the 6-hour robot access period the week of our first district event. Currently our autonomous modes are based on a timer which isn't very accurate or predictable. |
#21
Re: Encoder
Re: Encoder
Here is the information about the gear box if you want to look at its specification for the encoders http://www.andymark.com/product-p/am-2598.htm |
#23
Re: Encoder
Re: Encoder
Re: Encoder
Re: Encoder
Re: Encoder
Two CIM motors power the gearbox which moves the middle wheel. The front and rear wheels are powered by the middle wheel with belts. We use tank drive to actually drive and steer it.
#28
Re: Encoder
Re: Encoder
We did something similar with our H-drive, though since we used 4" wheels on the corners, we cut the rubber off the center wheels so they would float. Last edited by GeeTwo : 22-02-2015 at 01:35. |
#30
Re: Encoder
Except when going over the platform.
