Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
  #31   Spotlight this post!
Unread 22-02-2015, 11:55
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Talon sr, or SRX?
8 SRX on our robot this year. They're awesome, particularly cause of their small size. My only complaint is the permanent wires. It basically forces you to place your motor controllers next to the PDP unless you want to add connectors, and if any of these wires gets damaged enough, it bricks the controller. CAN is really cool but I don't think it's significantly better than PWM. I feel that there is no "better" controller between the SR and the SRX, they both have their advantages and their disadvantages.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #32   Spotlight this post!
Unread 08-05-2015, 16:28
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Yeah, I'd agree, the SRX's size is great, but those permanent wires only allow you to do temporary connections on the other side, so you're kind of stuck with always using Anderson connectors. The SRs are great and reliable but take up more space. Also, make sure you wire them the right way, otherwise... You don't want to know, unfortunately our team does.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
  #33   Spotlight this post!
Unread 08-05-2015, 17:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
... My only complaint is the permanent wires. It basically forces you to place your motor controllers next to the PDP unless you want to add connectors, and if any of these wires gets damaged enough, it bricks the controller.
If you're using limit or PWM control within the SRX, wouldn't it make more sense to connect the controller directly (that is, connector-to-connector) to the motor, then use a long line from the PDP to the SRX so that the data runs are shorter? Only the power lines and CAN bus would need to come out from the control board, rather than all the sensor lines. (I'm presuming that the feedback sensors are located nearer to the motor than to the PDP.)
  #34   Spotlight this post!
Unread 08-05-2015, 22:04
I assume by "bricks" you mean something other than "makes it never work again"?
The wires are repairable/replaceable. We got a beta Victor SP that was non-functional out of the box. All we had to do was open it up and solder the green wire onto its pad.
  #35   Spotlight this post!
Unread 08-05-2015, 22:28
Oblarg Oblarg is offline
AKA: Eli Barnett
The SRXs have far nicer wiring; even if you're using them in PWM mode, the ability to daisy-chain the built-in wires of multiple controllers that receive identical signals (e.g. in a drive setup) is extremely convenient.
They're also smaller.
"The breakfast of champions!"
  #36   Spotlight this post!
Unread 09-05-2015, 20:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
10 SRXs on the robot, of which we used 8 (4 drive, 2 lift, 2 intake). We used a limit switch wired to a breakout board on the Talon. We also sell the breakouts if anybody needs them.
We wired some SRs on our 2012 bot today, and I was surprised at how much larger they are.
  #37   Spotlight this post!
Unread 10-05-2015, 00:40
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is online now
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
SRX are awesome, because you can use their breakouts to connect encoders or limit switches. It makes your code lighter, and gives you more ports on the Rio. As an example, we'd use 8 PID subsystems with last year's talons. Now we have only one, because they are on closed loop.
TLR Talon SRX all the way
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
