Go to Post Every single person on the team, read the manual, cover to cover, NO skimming. Do not give the task of knowing the rules to a few people. Do not pass go, do not collect $200, READ THE MANUAL. - RoboChair [more]
Unread 22-02-2015, 12:59
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Handling Exceptional Cases in a CommandGroup
What about something like this?
private Command2 timeoutCommand  = new Command2();
public SomethingCommandGroup() {
     addSequential(new Command1());
     addSequential(timeoutCommand, 5);
     addSequential(new Command3());
protected boolean isFinished() {
     return super.isFinished()
          || timeoutCommand.isTimedOut();
Since a CommandGroup is still a Command you can override isFinished() to finish if a certain command or several have timed out.
I am unsure if the timed out command will need reinitialized or not. My gut says no.
