Go to Post Step 1. Understand the game and how to win the match and the event. - Chris Fultz [more]
Unread 20-02-2015, 16:32
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Onboard coprocessors/DHCP at events
We've going with a second computer on-board this year for the first time.
In years past, everything got static addresses, so our setup would have worked at home, on the field, and in the pits (where we have no DHCP).
This year, everything is using DHCP and letting mDNS sort things out (thank you, FIRST, this was a relief when switching between the robot and the school network).
but...
at the event, are we going to have to switch things back to static addresses so they work in the pits? or is there a better solution?
Unread 20-02-2015, 22:19
Re: Onboard coprocessors/DHCP at events
Are you using mDNS to find the coprocessor? If so, it should continue to work as long as the coprocessor assigns a link local address when there isn't a dhcp server.
Unread 22-02-2015, 20:04
fovea1959's Avatar
AKA: Doug Wegscheid
coprocessor is Debian-based, and we have avahi installed so we would have mDNS working, and avahi-autoipd takes care of allocating a LL address, so all is well. tested with roboRIO, coprocessor, and laptop on a hub with no DHCP in sight....
never done zeroconf before, this is pretty cool!
Unread 22-02-2015, 20:22
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Our on board coprocessor is using the static address 10.20.73.25.
Is this going to cause an issue?
Unread 22-02-2015, 20:36
Based on http://forums.usfirst.org/showthread...P-on-the-field you should choose an IP address outside of 20-199 and shouldn't expect the roboRIO or Driver Station to be at a certain IP address.
Unread 22-02-2015, 20:53
billbo911's Avatar
Thanks Joe! Simple change.
Unread 22-02-2015, 21:44
fovea1959's Avatar
AKA: Doug Wegscheid
billbo911: I suspect that when you are in the pits or on the practice field at an event with the radio in bridge mode, you won't have any DHCP server, so your laptop and roborio will come up with a 169.254.x.x link local address, your coprocessor will be 10.xx.yy.zz, and your coprocessor won't be able to communicate to the rest of your setup. That's only in the pits or on the practice field.
This was the situation I was worried about, but Joe advised to make sure that everything fell back to using a link local address, and that seems to be ok.
is your coprocessor Linux based? if so, install the avahi utilities, and they will take care mDNS and link local addressing.
