Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 22-02-2015, 12:29
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
RoboRIO changed its own passwords
It doesn't seem possible, but the roboRIO's admin password has changed to something other than blank, and will now not allow code to be run. I can still log into lvuser, but cannot su either. I can't run code from eclipse to the RIO, and I need an admin password to reimage the roborio. I have tried booting the RIO into safe mode, with the same result.
We have an extra RIO, so its not a huge predicament, but I would prefer not having a $500 paperweight.
Unread 22-02-2015, 22:20
Re: RoboRIO changed its own passwords
First, I'd ask around and see if anyone remembers changing the password.
If that is a dead end, contact the NI phone support. They know how to make paperweights into other objects, like robot controllers.
Greg McKaskle
Unread 22-02-2015, 23:06
AKA: Nick Schatz
Thanks, I have already contacted the only other person on the team that could have changed it. Where could I find the NI support number?
Unread 23-02-2015, 07:56
ni.com/frc and read the left column. It tells you the hours and numbers to call. This probably isn't something they can do via phone support.
Greg McKaskle
