Go to Post Nothing beats the local hardware store :). - Mike Martus [more]
Unread 23-02-2015, 00:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: LED Strip Power
Originally Posted by wmarshall11 View Post
Would throwing a couple of 5v regulators in parallel work for your application?
AAAAAAAAAAAAA!
Putting regulators in parallel is never a good idea unless you put enough resistance between each of the outputs to allow the variation in output voltage to go somewhere other than frying electronics.
