Go to Post We are here to support each other. - Mike Martus [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 20-02-2015, 23:20
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
Help putting an Adobe Illustrator image in Creo
Hey everybody,
I'm trying to 3D print a part for my robot and I would like to add my team's logo to it. It is in the format of an Adobe Illustrator image. I know it's possible, but I can't quite figure out how to do it. I'm trying to make an extrusion using the logo, if that helps. Here is the file: https://drive.google.com/file/d/0BwA...ew?usp=sharing
Thanks you in advance,
daliberator
Unread 21-02-2015, 19:39
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Help putting an Adobe Illustrator image in Creo
Originally Posted by daliberator View Post
Hey everybody,
daliberator
One way would be to put the image on your part as a decal and then trace over it in a sketch to make the extrusion.
Unread 22-02-2015, 01:43
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
How would you do complex images?
Here's the method I've used in the past:
You can import vector format files using the File System button in the Get Data tab in sketch mode. It might be a bit difficult to get it to precisely the right size you want (Creo does scaling really weird), but it should be possible. It will probably import with an extra set of lines, so you might have to delete an entire "surface layer" of lines on the image to make it extrudable.
To be honest, in my opinion it's often more pain that it's worth. I haven't found a "nice" way of doing it in the five years I've been working with PTC software. I'd love to see an alternate way of doing this.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 22-02-2015, 04:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Can't you export to DXF in Illustrator (with whatever layers you need), then import the DXF into the sketch? (It's been a while—and several versions—since I did anything like that, but I seem to recall that's how it can be done.)
Unread 22-02-2015, 05:52
You are correct - I made the assumption that a vector version of the image wasn't available.
That being said, doing complex images from sketches isn't a big deal. Break up the image into lots of simpler sketches and it doesn't take very long. I did it this morning to illustrate what I mean. Here is a screen shot of Creo with the completed logo.
Unread 23-02-2015, 07:32
skottmorris's Avatar
skottmorris skottmorris is offline
FRC #4909 (Bionics)
skottmorris is a jewel in the roughskottmorris is a jewel in the roughskottmorris is a jewel in the roughskottmorris is a jewel in the rough
There has been a detailed discussion of this topic on the PTC Community recently. Please take a look at the discussion titled "Logo on Creo part and drawing interface" for all the info.
Adobe Illustrator does support DXF output, so that should be a good option for you also. Once in DXF format, you can bring it into Sketcher or a Creo Drawing. I like the drawing option because you can scale the object a bit easier and export as IGES. Once the logo is in IGES format, you should be able to create a datum curve from file and import the IGES file with no worries about constraining the sketch in Sketcher.
Last edited by skottmorris : 23-02-2015 at 07:36. Reason: Missed the Adbode export option...
