Re: where do you source your power wire
A willing sponsor
. We found a couple of local power/electrical companies, and got them to donate spools to us. We just specified what we needed and they took care of the rest! |
Tell them you want signal wire, not power wire though. You want stranded cable.
We use Powerwerx zip wire for long runs that we want the power/ground to stay together. It's not the most flexible wire for tight bends, but it routes straight lines very cleanly.
http://www.powerwerx.com/wire-cable/red-black-zip-cord.html For electrical board wiring, we use high strand count silicone wire which allows for much a much smaller bend radius than the zip wire. This is more expensive, so we use it sparingly. http://www.buddyrc.com/accessory/silicone-wires.html Hope that helps! |
We purchased the bonded wire from Powerwerx for the first time this year. We love it. It makes everything that much easier. We had the same experience with a little thicker insulation giving a little less bend radius than we're used to having, but overall a good purchase and still much cheaper than anything we can source locally.
I'm with Jon. Went to a local electrical contractor, told them what we are up to, and asked for red and black stranded 14 ga and 12 ga, and got a full spool (500') of each donated.
I've found that my new team was somewhat clueless as to how easy it is and how willing folks are to donate to a robotics team, once they hear a bit about the team. It usually goes over a bit better than the marching band wanting to go to Florida for spring break and looking for money. Since I came to the team, we have donations of goods/services including the wire, a desktop CAD computer, a media laptop, some Lexan, limited printing/laminating services, and oh, yeah, from a primary sponsor, lots of aluminum and laser cutting of that aluminum and custom bending fabrication services -- all for free. Last edited by jvriezen : 23-02-2015 at 15:37. Reason: added spool length |
We use zip cord (black and red wires molded together) for most of our wiring. Powerwerx, MCM electronics, and McMaster all sell it, but MCM is usually the cheapest.
#7
MTW wire. Automation direct has it. Be careful not to get thhn/mtw. It is less flexible. Powerex. Monoprice has black/red bonded together. Certain appeal, but I don't have personal experience with it.
#8
I second Automation Direct. I buy MTW from them in semi truck sized quantity.
Mcmaster has a good selection of MTW/TEW too, that's usually where I order our 22 and 20 from. |
#9
We use MCM for red/black zip cord in various sizes. Check it out here...
http://electronics.mcmelectronics.co...p+cord&x=0&y=0 |
