Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 24-02-2015, 08:03
Re: Using xbox thumbstick to control servos on pan/tilt
Like Alan, I'm not sure what you want, but here are the two things I'd suggest.
1. Instead of setting the servo to the X and Y values of the joystick, use them to increment the value of the servo. You'll want to have a shift register that is initialized to zero, and add a fraction of the joystick each time through the loop. Send that to the servos.
2. Only update the servo value based on a button.
I'm also testing to see if the code snippets work when attached like this, but they should at least show you what the code should look like.
Greg McKaskle
Name:	Servo Tilt Code.png
ID:	18473  Click image for larger version
Name:	Servo Button Code.png
