Go to Post "there are two types of underprivileged teams; the ones who whine about being underprivileged and the ones that work to become privileged". - Undertones [more]
Unread 24-02-2015, 14:18
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Mschmeh144 is an unknown quantity at this point
2014 robot modification
howdy
as of today, now that our build season is over, we are getting to the old bots, and finally repairing them.
That said, our old bot, atlas, used tubing to provide the power to fire the ball. We had 9 1/2in sections, 4 in total, all of them shredded and broke. And they keep doing it, so we're looking for a alternative. We need something that's durable, but not as powerful. We use a winch to draw the launching piston ( non pnumatic ) back, and let the winch spool out to let it go. We must keep the winch system to draw the piston back, but we need other options to replace the tubing. Any ideas ? If it can be easily implemented, that would be preferable, but any other idea is welcome.
Unread 24-02-2015, 14:21
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: 2014 robot modification
Speargun band works well. It's more durable than surgical tubing.
Unread 24-02-2015, 14:23
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
A picture is worth a thousand words... It's had to offer advise without knowing the details of the Design that's already in place. Have you determined Why the tubing was shredding? We used tubing the entire season and it never broke.
2016: Lake Superior WFFA
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Originally Posted by Mschmeh144 View Post
howdy
Springs will last longer as long as they are not exposed to water/moisture.
Unread 24-02-2015, 14:33
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
I cannot get you pictures today as the entire assembly has been disassembled for cleaning ( the tubing literally exploded into thousands of chunks inside the arm it was housed in ) so after its cleaned I will get you photos of the assembly, not fully put together, but enough for you to understand how it originally went together.
Unread 24-02-2015, 14:39
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The problem is probably the age of the tubing (or more specifically, how long it has been exposed to air). In my experience, latex gloves (and presumably tubing) become brittle over time when exposed. I'm not sure if it's due to outgassing, a slow burn, or a combination of effects. If it was working last year at competition, replacing with the same product should give you several months of functionality.
Unread 24-02-2015, 15:10
AdamHeard's Avatar
Lead Mentor
As far as we can tell, it's the same stuff.
Unread 05-03-2015, 00:08
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
We used springs. Something did wear them out though, possibly overstretching or leaving it stretched for long periods. Keeping them in less extreme conditions should fix that.
Unread 05-03-2015, 00:47
Mulcahy's Avatar
Mulcahy Mulcahy is offline
FRC #0987 (High Rollers)
Mulcahy is on a distinguished road
We used Vulcan constant force springs. (3)x40 pounds each. There may be a voucher in the KOP.
