Thread Tools |
Rating:
Display Modes |
Re: Attempting to SSH into the robot breaks code deployment
Are you sure you were trying to log in as the correct user over SSH? If you are using Linux (or Mac), the default user will be you username, not admin or lvuser.
You are no longer able to deploy code because the Eclipse plugins use SSH and try to login with a blank password, which you changed. I was able to use SSH fine on our roboRIO, using the blank password. |
As for deploying, is there a way to deploy with a password? There doesn't seem to be a way to set one from the WPI options in Eclipse. If not, I guess we can live without a password. Last edited by nathanwalters : 24-02-2015 at 21:23. Reason: clarifications |
It is possible to change the password by modifying the file: ~/wpilib/java/current/ant/build.properties. There is property called "password", which is blank by default. Keep in mind that this will probably be overwritten each time the plugins are updated. It might also be possible to override that property in the project specific "build.properties" file, but I have not tested this.
I've logged into our roboRio with the user 'lvuser' and no password. That's the login I found in the ant build scripts. Worked fine. I'm not sure what the permission level of lvuser is, or even if there's sudo access, or what have you, but it got me in.
As far as passing in params to the JRE to get it to make a heap dump look at the 'robotCommand' file in ~/wpilib/java/current/ant on the development machine. The ant scripts will scp (copy) that over that to the robot and by default it reads: Code:
env LD_PRELOAD=/lib/libstdc++.so.6.0.20 /usr/local/frc/bin/netconsole-host /usr/local/frc/JRE/bin/java -jar /home/lvuser/FRCUserProgram.jar Disclaimer: I haven't tried this... just my assumptions from poking around the build system. Last edited by Justin Buist : 03-03-2015 at 19:56. |
