Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.40 average. Display Modes
Unread 25-02-2015, 12:05
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Quotes from the Chief Engineer and I
(warning: the following story is about matrices.)
Today in AP Computer Science my teacher was lecturing us about how when creating a matrix, for example Matrix[3][3], the first set of brackets is rows and the second is columns. While this is usually convention, it is not actually how a matrix will work as the way we draw arrays, like the one above:
[0,0][0,1][0,2]
[1,0][1,1][1,2]
[2,0][2,1][2,2]
Is just a way for us to visualize, and not how they are actually created in the computer, as my teacher so believes. That is why I could draw the above like this:
[0,0][1,0][2,0][0,1][1,1][2,1][0,2][1,2][2,2]
or even this:
[0,0][0,1][0,2]
/////////////////[1,0][1,1][1,2]
//////////////////////////////////[2,0][2,1][2,2]
or even if I so choose I could draw it like this:
[0,0][1,0][2,2]
[0,1][1,1][2,1]
[0,2][1,2][2,2]
After a heated debate with my teacher over whether or not a computer actually builds out an array in the ordered fashion like this:
[0,0][0,1][0,2]
[1,0][1,1][1,2]
[2,0][2,1][2,2]
We decided to just dropped it. But now to the point of the post. My Chief Engineer and I were discussing the above designs and how all of them will work because you're drawing an imaginary things and it doesn't matter if you draw the cells as gummi bears it will work when I turn to him and say "People don't care about convention so long as you comment it enough!" (-Lord Supreme Programmer Isaac and Chief Enginerr Robert, 2/25/15)
So if there is a lesson to be learned it is comment your code, kids. Even though good code should speak for itself.
Unread 25-02-2015, 12:18
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Quotes from the Chief Engineer and I
How members of an array are stored and accessed is a function of the programming language. It is not something one should worry or argue about since the language will reference and de-reference everything for you. "Row" and "Column" mean nothing to the compiler. Notation has nothing to do with the physical location since memory is laid out so one accesses word-sized elements in sequence. In C and C++ matrices and arrays are really done with pointer arithmetic - google it.
Unread 25-02-2015, 12:24
AKA: Isaac
Originally Posted by wireties View Post
How members of an array are stored and accessed is a function of the programming language. It is not something one should worry or argue about since the language will reference and de-reference everything for you. "Row" and "Column" mean nothing to the compiler. Notation has nothing to do with the physical location since memory is laid out so one accesses word-sized elements in sequence. In C and C++ it is really done with pointer arithmetic.
That is exactly what we said! We were trying to convince our teacher that you don't actually store these numbers in little ordered cells! We could say that when you create a Matrix[][] the first brackets are potatoes and the second are tomatoes and it would still work. It really frustrates me that my so called AP Computer Science teacher hasn't taught this since haskell, had to learn Java over the summer (he pronounces it as Jaiva, it can get irritating), and said, and I quote, "Java is the most popular programming language because three billion devices sounds like a lot". He just makes me want to smash my head into a wall. At least he got us 4 megabyte jumpdrives!
Last edited by King Nerd III : 25-02-2015 at 14:23. Reason: changed paskell to haskell
Unread 25-02-2015, 13:04
philso philso is offline
FRC #2587
It sounds like your teacher is a bit behind the times...
Unread 25-02-2015, 13:05
AKA: Isaac
Don't worry, they will actually hold a surprising amount of documents. For just some simple Java programs they would work pretty well, but thankfully they were 4gb.
Unread 25-02-2015, 13:21
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
I think you mean "Pascal". And C/C++ (counted together) is far and away the most popular programming language.
Unread 25-02-2015, 13:27
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Paskell sounds like an odd mix of Pascal and Haskell. That could be interesting...
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 25-02-2015, 13:29
AKA: Isaac
Sorry, typo. I meant Haskell. Only other language he knows. And the quote about Java was from him, probably one of the funniest things he's said as it reminded me of the quote from the Java install.
Unread 25-02-2015, 13:31
AKA: Isaac
That would be weird. Have you ever used Chicken or LOLCODE? They look really ridiculous.
Unread 25-02-2015, 13:34
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Wait. They still make them that size?!? Seriously, google doesn't show up when I search that size.
I remember winning a 64mb drive in college for a CAD competition about 9 years ago. THAT was a big deal.
Unread 25-02-2015, 13:45
AKA: Isaac
Well here was the order of events:
1. He asks if they still make firesticks
2. I explain to the class what a firestick is
3. He asks if they would be useful or if we would prefer storing them in the "Lightning Cloud"
4. He says that we will buy 4mb firesticks from Circuit City.
5. He shows up with 4gb jumpdrives he bought for $25 a piece. 25 dollars. Where did he find them so expensive?????
6. We explain to my teacher how a gigabyte and megabyte are different.
Unread 25-02-2015, 22:45
jeremylee's Avatar
jeremylee jeremylee is online now
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
When I was in school, I got a free 32mb with a $1500 dell laptop, score!
OP, it's crazy how quickly people can fall behind the times without even knowing it. Pick your battles in this kind of situation as some will never be won with either knowledge or wisdom. Might as well offer a coffee and talk about the weather instead.
Unread 25-02-2015, 22:50
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I remember buying a 128 MB drive. This was about when they finally became "good", and it was on sale for the same price as a 64 MB version (at least $20).
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 25-02-2015, 22:57
AKA: Isaac
It's not like he is behind the times, he has a MacBook Air and a nice desktop for class, but the old desktop plugged into the archaic projector is just hilarious. I don't know what the plug is called, but it is larger than a VGA! God, it looks ridiculous!
Unread 25-02-2015, 23:07
Sometimes, the older technology JUST WORKS. And that is what is important in the long run. And it wasn't too long ago that FRC used 37-pin ports (like, last year--and there's still the MXP).
I believe you were looking at some form of serial or parallel port. Probably a many-pin one. VGA, if I'm not mistaken, is another form of serial port. You use serial ports on a near-daily basis if I'm not mistaken--on the Universal Serial Bus (USB).
(Incidentally, I had to boot up a Windows 2000 computer last night. Why, you ask? Because it can run program X. Program X serves a key function in this application. Old technology? Yep. Does it JUST WORK? Yep, unless someone turns it off...)
