Go to Post Engineering fundamentally comes down to problem solving, and if the students can't get excited and inspired by the problem solving process because someone has spoon fed them a solution, then nobody wins. Give a man a fish, he'll eat for a day. Teach a man to fish, he'll eat for a lifetime. - kevinw [more]
Unread 25-02-2015, 15:39
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Re: Inverting Talon SRX
Originally Posted by FrankJ View Post
The procedure is documented in talon programming manual. But the "forward" limit switch stops the controller in the "forward direction" That might be down. Also if you are using normally closed limited switches you need to set that in the talon web dashboard. The default is N.O.
I looked in the manual in there really is nothing as easy as random_motor->SetInvertedMotor(); which is inconvenient. A search of the manual brings up inverting a slave motor, but it doesn't really help. I think we will just stick with moving the forward limit switch to the bottom, and reverse to the top.
Thanks for the help!
Unread 25-02-2015, 15:47
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
You will need to fix it in the wiring. If the Talon is green (positive throttle) it will only check the forward limit switch. What causes the Talon to be green (closed-loop, slaving, slave-invert) instead of red (Reverse) can be controlled by Reverse Sensor and Reverse Closed-Loop output. But the limit switch is compared against the final output.
Unread 25-02-2015, 15:50
AKA: Isaac
Yeah, that's what I thought. I wish we didn't have to do that, but as long as it works it's fine.
