Go to Post After all of this is said and done, think about how much more you all will know about the lovely state of Montana and other things not related to robotics. :) - Madison [more]
Unread 25-02-2015, 19:52
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Gyro's angle value going up
Originally Posted by Mike Bortfeldt View Post
I've used similar gyros in the past and was not happy with their performance. In my experience, the Analog Devices gyros seem to give much better results. It's certainly possible that the newer models from Pololu have improved, and I would be interested hearing your opinion of them.
Having learned what I have in the past few days (see this thread on usfirst), I'm not surprised; the gyro class uses hardware acceleration unavailable to an I2C gyroscope. While we will look at the suggestions there, there's the possibility of using an arduino to turn the I2C gyro into a rotation encoder, or just buying an integrated solution. The NavX would also be under consideration if it were actually available.
