Go to Post Incidentally, the best Delphi is ChiefDelphi! :) - Max Lobovsky [more]
  #38   Spotlight this post!
Unread 25-02-2015, 21:44
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Re: functions for auto
Originally Posted by Arhowk View Post
Oh my apologies, I never saw your edit. Good to see that you were able to resolve your issues. You chose the correct path for all of them.
How did it work today?
I would.... o.O sometimes I use Sublime or NP++ because it's overall faster and doesn't gun my processor like Eclipse does than just once-through in eclispe
Everything seemed to work for teleop, because this is all we really had to do...
But I did do a quick run for autonomous and I noticed a few things, one of which was the robot did not move when I called the move function.
I think this is because I would enter a value of 3000 or 450 into the parameters of forwardMove when it should be negative (our encoder only likes negatives I don't know if that's normal...)
Also I noticed that there was a long delay in between functions, almost 3 - 5 seconds. I thought this was odd seeing as I only have a 0.5 timer delay between functions.
