Re: Inverting Talon SRX
Is it really that important that forward be up!? I get that it's a little more straightforward, but if you reverse the output and make the top "red" and the bottom "green" then you don't need to rewire, right? You were wanting a software workaround, so a slight inconvenience of needing to invert a number seems reasonable.
I can't speak for Omar, but I'll guess he meant what he said, assuming that the team wanted the polarity of the control values to remain unchanged. My assertion assumed that polarity is a rational trade off to rewiring.
I think what Omar is saying (not to put words in his mouth
) is the limit switches work directly on the output of the controller which there is no reversing. IE the green & red leds relates to the polarity of the output.Hopefully Omar will confirm or correct this. |
