Go to Post CAD or it didn't happen - R3P0 [more]
Unread 26-02-2015, 01:18
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The math of the cans...
So after discussing with some of my team members about whether we should make our step can grabbers faster (Yes!) I decided to run some numbers on whether it would be worth it in elims to grab, say, 2 cans, faster than anybody else. Or 4 cans but remove something major from our bot.
Or literally have a bot made of can grabbers that grabs all 4 cans in a fraction of a second, using superior firepower (all the cims + as many motors and pneumatics as you can fit in that 120lb-limit), plus our drivetrain for shoving noodles or totes.
I am not counting the value of noodles due the unknown factor in how long it takes to put them in cans or how many can fly to the other end of the field.
Most of this is calculated with a 3-stack assumption for really good teams. This is lowballing IMO, but you can see at the end that more stacks/ team means a more effective can grabber.
With 2 cans to each alliance, then it's evenly matched points-wise per alliance. If, in one match, an alliance can score 5 full stacks of totes + can (not counting noodles here) and one non-can stack that's
36 points/stack * 5 stacks + 12 points for non-can stack = 192 points.
A high number, to be sure, but doable depending on where you are (thankfully, my team is not attending Dallas lol). With no cans, only the 3 you begin with, then you run a point total of
36*3 + 12*3 (tote-only 6-stack) = 152 points.
Okay, that's not too bad, your average still remains relatively good, especially if against other teams you can match taking 2 cans off the step. Plus, you can still score totes instead of picking up cans once you run out to lessen the impact. The other team still gets only 192, which could be beatable overall with other elims scores.
TL;DR: If a really good robot this year can score 2 canned stacks (as in, that's the effective maximum for even the really good teams) then the can grabbing bot is somewhat ineffective in elims. Very situation-specific as to its other capabilities.
But...
If two alliance members can stack 3 fully loaded stacks, and the can grabber can only grab 4 cans, then that's a total capacity of
6*36 = 216 points.
with canned stacks. By contrast, if you can only get 2 cans off the step and a decent stacker (2 loaded stacks) with the two good stackers that's
5*36 + 3 * 12 = 216 points.
TL;DR: At any level of competition, two demon-stackers and a decent stacker w/ two-can grabber would do as well as an alliance containing a bot that grabs 4 cans and flops over with two demon-stackers. If the can-grabbing-flopper can cap 6-tote stacks with cans or load cans with noodles or something, then it has the upper hand.
If an alliance with the capability to get 4 cans the fastest makes it to semis, then it gets very interesting. Because each team plays 2 matches, and there's only 4 teams playing, a lowered score due to loss of the cans could impact the score enough to outweigh the fewer points that a specialty can-grabbing bot would make compared to a fast stacker.
Using the 3-stack/bot model,
4-Can grabber alliance:
6*36 = 216 points.
Other alliance:
3*36 + 6*12 = 180 points.
In matches without facing the 4-can grabber, but still obtaining two cans:
5*36 + 4*12 = 228 points.
Cutting it pretty close there at 228 vs. 216. But, at 6 matches worth 228, and 2 matches worth 180, the average is only 216 points! What an interesting coincidence.
So if you have that 4-can flopper, pushing some noodles around could possibly win you semis.
TL;DR: A 4-can bot that does nothing else can tie with an alliance made of really good stackers if it has stackers of similar level oiance in semis. It can beat the opposing alliance if it can push stuff around or do anything other than flop over.
On Einstein, the 4-can-and-flop is an almost guaranteed win. If every robot there can make, say, 3 loaded stacks over the course of the match, this is the flopper's alliance:
6*36 = 216 points.
This is the other alliance:
In order to beat the flopper's alliance, the opposing alliance has to score an additional 18 totes. That's 3 extra stacks, or essentially one entire extra stack per robot on an alliance. And everyone's on Einstein here. 3 stacks is a lot of upper hand.
I'll have to wait until Dallas to see what the metagame is- how many stacks can the best of the best get? 3? 4? 5? The more stacks they can make, the more effective the can-grabber-flopper bot becomes (assuming the alliance is made up of good robots), as it becomes increasingly likely that they can score all 7 canned stacks every single match, and the opponent's average score drops even lower.
Take Einstein again. The opposing alliance has to make do with 3 cans. With only two functioning robots on the flopper's alliance after auton, at a capacity of 4 stacks per non-can bot, the flopper alliance makes
7*36 + 1*12 = 264 points.
Compared to
3*36 + 9*12 = 216 points for the no-canners.
AKA 24 extra totes to score to catch up. I'm not doing the math for semis, but I think it's still going to be pretty close for a can grabber vs. everybody else with higher points totals, although the can grabber would have a better upper hand.
So to summarize:
-On Einstein, cans are important. It could all be decided in the literally the first second.
-In elims, cans are important, but not as much. A can grabber has to still carry its weight, at least a bit.
-If a really good robot can stack 3 canned stacks per match, then a 4-can grabber is about equal to a 2-can grabber with 2 canned stackes in a match.
-If the metagame is 3 stacks/bot, then the 4-can-grabber is pretty good. As the metagame gets better, to 4 or even 5 stacks per robot, the value of the can grabber becomes much higher to the point of being overpowered.
-If a very high-seed team with 2-can grabber picks the next fastest 2-can grabber, it stands poised to win if it can pass through quarterfinals.
Personally I wouldn't want to build just a 4-can grabber as the robot unless we spent all season getting the code and mechanism perfect to the point where it was a guaranteed grab of all 4 in 1/10th of a second, and I knew it was impossible to be faster than us.
Which is totally possible.
Thoughts and errors in my concepts? Assuming all tote stackers are created equal is a fallacy, but it doesn't look like there will be a massive fissure between the fantastic teams and the good teams this year. Still, the 4-can flopper has to do something else other than grab the cans...
Unread 26-02-2015, 01:29
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: The math of the cans...
I hope on einstein both teams can grab all 4 bins from the middle, and they all grab them at the same time and it comes down to whose grabber is stronger.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 26-02-2015, 01:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Zip ties on the can or just can shear is my guess. Those things are only so strong.
They might end up simply getting rid of the center cans or something. Nobody could let go for the entire match.
Unread 26-02-2015, 01:50
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Gamesense had a good discussion on this. Your alliance still has to execute even if you get all 4 cans off the step. A knocked over stacked could end an alliances hope at making it out of any round.
Also noodles in the RCs mean that the opposite alliance needs another 3 totes per stack to catch up. There is something to be said for efficiently noodling the cans and ensuring the noodles stay in the cans. One of the reasons why so many people are amazed by 148 is their ability to play two different roles. They can both acquire cans, put noodles in them and put them on top of stacks while they stack at the same time. If that gives them an extra stack or possibly two out of the feeder station (say 4 or 5 by one robot with littered RCs on top) that is a huge advantage.
The average stacks per robot gets harder as more good teams get on an alliance. 30 totes behind the glass (5 stacks) and 18 right side up in the landfill (3 stacks). The 9th stack is likely way slower for even the best alliances since it's either upside down or pulled from the step.
The arms race (as talked about on GameSense) will be very interesting this year. It's going to be like 2011 but worse since teams can keep throwing power, weight, and design time at it. 3310 has set the bar at their reported 1/4 sec pull. I'm waiting for the 1st team to start wind tunnel testing their mechanism to reduce drag.
Unread 26-02-2015, 02:08
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
start wind tunnel testing?
Unread 26-02-2015, 02:10
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Common, who doesn't like seeing an entire season decided in less than a quarter of a second?
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 26-02-2015, 02:19
faust1706's Avatar
that's how breakaway was on einstein. If you didn't stop....469(?) in autonomous you lost the match.
Unread 26-02-2015, 02:22
Andrew Lawrence
Posts: n/a
469(?)
Yes, 469.
Unread 26-02-2015, 02:25
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Just the last match of it.
Consider:
http://www.youtube.com/watch?v=pmyph...ature=youtu.be
Even if it's sped up, it's definitely possible to reach those speeds and beyond with the infinite motors this year.
Unread 26-02-2015, 02:26
Engineering Coach
Have I underestimated you guys?
We all signed up for this drag race, right?
Unread 26-02-2015, 02:31
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Forget wind tunnel testing, we need to start looking at the relativistic effects that could be caused by time dilation at high can grabbing velocities...
Seriously, don't you guys have a regional to be getting ready for or something? Get some sleep.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 26-02-2015, 08:06
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I'm waiting to see a robot towed over the step in a tug-o-war.
___________________
- Tennyson, Ulysses
Unread 26-02-2015, 08:35
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
I asked that tug-o-war question on Gamesense after seeing all the auto can grabbers.
Cans will be HUGE in Einstein...in Elims not so much
I still think there may be fouls called over alliances "fighting" over RC's from the neutral zone but those decisions should be rare.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 26-02-2015, 09:50
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I really think at this point having the ability to grab cans in auto will just make you 1) a more appealing robot to scouting teams 2) prevent the other alliance from potentially scoring those cans which will be good for you even if you don't score them yourself 3) Make you more valuable in auton to robots who have a 3 tote auton, or 148 who can get all 3 cans and all 3 totes.
Ultimately, I think grabbing all 4 cans in auton with one robot will prove to be too slow unless someone can get all 4 crazy fast like 3310. I will be willing to bet that on Einstein, if divisions get lucky, the winners will be an alliance that can grab all four cans with 2 robots, while the third does a 3 tote auton, or even just drives forward to the auto zone. I am not too sure yet depending on alliance selections and the depth of the divisions.
Unread 26-02-2015, 10:24
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
The CAN race is the only thing that keeps this game from a glorified skills challenge.
The GDC will improve the overall game by allowing ONLY 1 team from each alliance to touch the cans.
(restriction only applies in the autonomous period)
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
